Question about HP LaserJet 2420 Printer
The display does not work anymore. - HP LaserJet 2420 Printer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Hi, Printer Has Blank Display Issue Description: Some customers may report that the control panel display is not working on their LJ2400 Series printer. Most of the units are right out of the box. This goal of this document is to help you troubleshoot the problem and provide a solution for the customer. Symptoms Customers will see: Printer powers on, motor rotation and fan sounds can be heard during boot cycle, but the control panel display is blank and there is no backlight . Printer prints engine test page. Printer powers on, motor rotation and fan sounds can be heard during boot cycle, but there is backlight . Printer prints engine test page. Troubleshooting requested by engineers: BACKLIGHT PRESENT, BUT NO TEXT DISPLAYS Disconnect all connections to printer except for power cord. Plug power cord directly into wall outlet and power cycle. Can motor rotation sounds be heard? Reseat memory DIMM in slot. Check cable connections on formatter ? particularly control panel power (J4), ECU-Formatter flat ribbon cable (J5), and power from the ECU (J6). NO BACKLIGHT Verify that the engine is powering up when power cycled by listening for motor rotation sounds. Ask the customer to print an engine test page. (See photo below for access to engine test page button.) If engine does NOT print test page, problem is with the engine, not formatter or control panel. (Service required.) Check cable connections on formatter ? particularly control panel power (J4), ECU-Formatter flat ribbon cable (J5), and power from the ECU (J6). Verify boot select jumper on the formatter PCB is installed on the bottom two (correct) pins (see photo below) to ensure the unit ?boots? from the firmware chip on-board the formatter. NOTE: The BOOT SELECT position (top two pins) is only used to boot from a FW-loaded compact flash card. If incorrect, reseat boot select jumper onto the bottom two (correct) pins. Attempt to print a configuration page ? ?back? button (x3, to clear any undisplayed messages) -- check button -- down arrow -- check button -- down arrow -- check button. If configuration page prints, verify contents and, assuming you find nothing wrong with configuration, you may assume that the problem lies with the display portion of the control panel. Rgds, Nikhil
Posted on Sep 09, 2009
Bosch Dishwasher LED Readout Glows Red But No Writing
Dear Sir:
This is a electronic problem you must Snap the new board, and replace it with carefully. Turn off the panel, and proceed.
Call to the factory and get answer if you can get some rebate for return the old board defective vs new one.
God bless you
May 15, 2012 | Bosch 24 in. SHX99A15UC Stainless Steel...
Hi I Have a Sony LBT LX5 Hi Fi System, the front display panel does not light-up anymore, but the machine still works.
Hello
The display of these type of sets are of vaccum type one, which will have a heater filament inside. Like any other vaccum bulbs, the filaments of these part may get opened; and can be said damaged. It is a glass vaccum unit, can be located just behind the display window, will have to be replaced as a unit. OK.
Jan 04, 2012 | Audio Players & Recorders
Display is not working.the display is white
First we have to check if its an actual issue with the display,if its not working anymore.Please try with a power drain.For this, you have to remove the battery and wait for a few minutes and then connect it back and power it ON.
Nov 19, 2010 | SanDisk Sansa Fuze MP3 Player
My player doesnt work anymore display is not working and it doesnt turn on anymore? what do i do?
Hi, thats look like its the power supply,
a zener diode and some caoacitor or its could be the fuse
if the fuse is dark burn inside thats indicate a good short circuit
on the primary side off the power supply,
hope that will help
regards Alan
Oct 09, 2010 | Pioneer BDP-51FD Blu-Ray Player
My DS lite has fallen: bottom-display won't show...
The bottom screen has gone out. They are pretty easy to fix and can be purchased from ebay and other places also.
Feb 08, 2010 | Nintendo DS Lite Console
Caller id is not displayed anymore
i dont know how your sistem ist working. Im just looking for a instruction for the RX-DS45 to change or add the radiochannel
Sep 02, 2009 | Panasonic KX-TG6500 Cordless Phone
Caller ID Doesn't show up Anymore
display ic got short internally that has to be replaced.this many a times happens due to over charging or the moisture collected on the circuit makes it short when connected for charging.
Mar 02, 2009 | Uniden Cordless Phone
Nokia 6500s
hi i have a nokia 6500s.... it used to work ok. but now i cannot play games anymore it says supportive file nothing to display.... i tried getting new ames but it still says the same and another thing my calculator disapeared too
Oct 22, 2008 | Cell Phones
Display
you need to replace the flexcable and lcd to correct the problem.....take the phone to a mobile service center to get it fx or a professional mobile tech.
Nov 11, 2007 | Motorola Mobility RAZR V3
HP LaserJet 2420 Printer Logo
522 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
