Exercise & Fitness Logo
M
Mike Gibson Posted on Aug 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 5.2t Horizon Treadmill turns on, but as soon as I push the start button it blows the fuse to the outlet. I tried re-setting the breaker about 6 times and then I started smelling smoke. I opened the
I am wondering if I should order a new control board or if there may be another problem. Thank you.
Ronald Thompson
Level 3:
Master:
  • Master 560 Answers
  • Posted on Aug 10, 2014
Ronald Thompson
Master
Level 3:
Master:
Answers
560
Questions
0
Helped
134828
Points
1334
First of all, never reset a breaker more the once. If it trips twice it's not going to magically, "heal " if you keep resetting it.
Two possibilities. Bad breaker or internal short in the machine.
Replace the breaker with one not tripping and then check out the machine for shorts.
Just switching out parts is a less specific and more costly solution.
5 Related Answers
raj somaiya
  • 5370 Answers
  • Posted on Jan 23, 2011
SOURCE: Horizon Fitness Treadmill - Quantum
Check the treadmill "continuity" , the treadmill connections correctly grounded. If that is checked ok then either the outlet itself is bad .Try plugging the treadmill on another stronger outlet, such as a kitchen outlet..But if its still shorting out and blowing the fuse then its internal motor problem.The motor or its wiring is got weak,so when you press the start button the motor starts and treadmill turns off and blow fuse.--------- This should help.Thanks.Helpmech.
paul miles
  • 456 Answers
  • Posted on Jun 22, 2011
SOURCE: Hi. I have a
hi.
the circuit breaker probably only covers the motor anyway, and if this is the case then the problem has been isolated already.
it sounds like the motor has burnt out, and there is a short in it somewhere. the best (and safest) thing to do is to remove the motor and either just replace it, or have it tested by an electrician.
most repair shops will happily test a motor for free if you take it to them. it should only take a few minutes.
take the circuit breaker to them as well, as it is possible to have a faulty circuit breaker.
please feel free to ask if you need more advice.
hope this helps
Anonymous
  • 76 Answers
  • Posted on Jun 23, 2011
SOURCE: I have a Horizon T62 Treadmill. Motor stopped
I want to change my face book security code for any time to time there for pleace help me
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Oct 28, 2011
SOURCE: treo treadmill blows fuse hear makes banging
Dear Sir:
I will try to help you, please be patience, carefully, and you must use basic tools:
Now you have combined problems: mechanical +Electrical.
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
BURNING SMELL
If you can walk on your treadmill but you get a burning smell from it, you have a bad problem and discontinue use immediately and unplug the treadmill.
Burning smells are most commonly associated with the following problems:
1) Very high belt/deck friction.
2) Short in the motor.
3) Short in the wiring or electronics.
4) Literally cooking the lacquer or cardboard core (on cheap machines) in the motor from belt friction or a drive system
obstruction.
Friction is the #1 cause of this problem. Many cheaper treadmills have a motor with a cardboard core (people wonder why we are so
down on cheap treadmills) and if the voltage and amperage through the motor heats it up sufficiently, it begins to smolder. If this is the
case, you normally have to replace the belt and the motor and inspect the deck. If the armature has cooked enough in the motor, you
also have to replace the motor.
If the belt and deck check out OK, check for a short in the motor. You can run the motor with an independent power source like a fullycharged
cordless drill battery to see if the symptoms are the same. Click on the following link for our motor test.
If the belt and deck check out and the motor is OK, then check your wiring and electronics for signs of scorching and replace the
appropriate part(s).
If you need additional assistance, please reach me.sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on May 09, 2012
SOURCE: my horizon 4.1t treadmill will incline/decline but does not run. showing an e1 error. please help
1) Adjust the speed sensor, clean, and tight the connector very well
see the diagram
2) Lube the deck belt, by lack of maintenance,
3) Test the motor input voltage, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor,if there are the board is ffaulty.
RUN the software calibration for diagnose and troubleshooting.
2answers
Horizon GS1035T Treadmill. Were are the fuses on it please?
https://support.horizonfitness.com/hc/en-us/articles/4410673893261-Horizon-Fitness-GS1035T-Treadmill
2answers
2helpful
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Horizon 4000 treadmill is tripping mains circuit breaker and blowing plug fuse
see my personal TIPS and test the motor.
2) the main board can be faulty, replace
3) lube the machine for a DECK belt , the resistance can be another cause.
4) lube the roller bearing too.
5) test the power supply for faulty
see the block.
God bless you
My horizon t202 treadmill wont start i cant even located the on/off switch where is that? I see the reset button
Normally the button and reset is in FRONT from the machine is you stand from the machine in the lower part, Is RED and at the side is reset button.
2) Test the fuse inside see the block diagram , test and replace.
3) Test the power cord for open, break
4) test the outlet wall, reset the breaker from you house, DO not use any extension cord. and proof again.
5) If you can NOT resolve the problem, you must call to the service tech,.maybe you have problem with some component, inside capacitor, transformer in the power supply.
God bless you
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
I was using my Horizon Treadmill T1201, and in the middle of my workout my circuit breaker was tripped and lost power in my room. When I got power back, i turned on my treadmill and it reads a 5101 error...
Dear Sir:
You have a big SHORT CIRCUIT inside from your machine.
1) Test the input voltage and see the c. breaker reset 2) Test the fuse inside with your DVOM. 3) See if some wires is loose and tight 4) See if there are some component burn 5) Test the input voltage motor, if there are the motor is faulty 6) Test the output voltage for input voltage motor is there are NOT the board is FAULTY.
Of course you must sHURE the outlet from wall is o.k test the ground wires,and see any loose wires, or touching between them. DO NOT USE ANY EXTENSION CORD for your treadmill.
1helpful
I have a T700 treadmill and the breaker blowed. I got a another breaker but it also blowed. What can be making the breakers blow ?
Hello, what do you mean by the breaker is blowing? The one in the fuse box or the switch on the back of the treadmill?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
3answers
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Top Horizon Exercise & Fitness Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
