Question about Sony Car Audio & Video
Rear brake lights inoperative including high level brake light?
  • 52 Answers
Had the same problem with my signal
either your system is to loud and rattling a connection loose
or your positive cable for your amp is hooked to the hot side of your fuse panel under the hood this can cause a lot of weird problems
Posted on Jul 02, 2009
What else can i do?My brake light are no working and i already change the switch pedal and the fuse its ok what else can be wrong? Lincoln town car 2004
Check the light bulb fittings are not corroded or disconnected.
Otherwise a long wire with clips on to check the circuit is complete from fuse to each side of the lamp fitting, or in between
Nov 18, 2015 | 2001 Lincoln Town Car
I have code p0573 saying brake switch A is high although brake lights are working ok, can anyone help please
Possible causes
- Faulty Brake Switch
- Brake Switch harness is open or shorted
- Brake Switch circuit poor electrical connection
help.jpg What does this mean? When is the code detected?
The P0573 codes is set when the stop light switch signal is too high.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Stop light inoperative
- Cruise control system inoperative
P0573 Description
When the brake pedal is depressed, the stop light switch sends a signal to the Engine Control Module (ECM). When the ECM receives this signal, it cancels the cruise control.
Aug 29, 2014 | Cars & Trucks
Megane coupe 1999 rear fog indicator comes on when brakes pressed, fogs don't work or high level brake light.
I have the similar problem with my 2000 model. On mine I have narrowed it down to the rear light cluster on the right as you look at it from the rear (drivers side in the UK). Here's how I fix mine, although it does keep happening every now and again:
Remove the lights cover from inside the boot, it is held in place by a couple of plastic nuts.
Remove the strip of lights that are clipped into place.
There is an electrical connector block attached to the now removed light cluster. Undo this and the whole set of lights will be free.
Where the connector block fits to the light cluster clean all of the terminals. I use one of my wifes nail emery boards.
Make sure the female connectors on the connector block are all fairly snug so when put back together it is a tight fit.
Clean with electrical contact cleaner if you have any (not really necessary but I had some anyway).
Reconnect the block and test your lights, put back together.
I suspect it is an earth fault but I ran a separate earth to the unit but it didn't improve.
Other faults I noticed is the rear wiper operates when the front one only is on and I touch the brakes. Also when I lock the car when the indicators flash to show it is locked the rear high level brake lights flash as well. I was thinking of trying another light cluster, but 25 pounds from a breakers yard seems a little steep for a minor irritation.
Aug 02, 2014 | 1999 Renault Megane
1984 GMC G3500 has multiple lighting issues... Headlamp high beams work, low beams do not ( brand new bulbs and interior switch ) Passenger reverse lamp inop... Driver side rear blinker/brake light stuck...
seems you have several different problems. High beam working and no low beams=dimmer switch is bad. Reverse lamp not working=bulb socket bad,wiring broke,bad ground at back
Brake light on drivers side stuck on=brake light switch
Nov 18, 2017 | GMC Jimmy Cars & Trucks
Camry CE 2001: Changed the brake light in the
hi the rear high level brake warning light in rear screen ? works with the other two brake lights at same time when you press brake pedal with ignition on ? so may i suggest you check the other brake lights are working ? if not ? check these bulbs? reason being that from the symptoms you describe that high level light is staying on ? it would suggest that the brake light switch at the pedal is not operating ie not putting brake lights off when pedal is off and would suspect the brake lights have been on for some time and burned bulbs out due to the brakelight element in bulbs are high wattage if you check on what i have suggested? and is the case ? come back and will advise you how to adjust brake switch easy diy hope this helps? best wishes from the uk
Jan 01, 2010 | 2001 Toyota Camry
My brake light and a light that looks like a car with //\ at the bottom are on. brake fluid is fine and all rear lights are working
Your brake light is on because your brake fluid is probably low in the brake master cylinder. As the brakes wear, the fluid level drops proportionally. A switch in the brake master cyluinder measures the fluid level.
The //\\ light indicates you have a burnt out tail or brake lamp. All of the rear lamps are checked by a sensor, including the one in the rear window.
Oct 20, 2009 | 1996 Toyota Avalon
Rear brake lights inoperative . The upper brake light on trunk deck works, but the lower lights in the main assemblies are inoperative.
That is a little strange, but could be just bulbs have blown. Switch must be ok if high mount works, so check bulbs first. Unless there is a separate fuse you could check that too.
Sep 24, 2009 | 2006 Cadillac CTS
Brake lights inop on my 2000 ram 1500
check the fuses under the hood including the ones marked as trailer fuses
Jul 24, 2009 | 1996 Dodge Ram 1500 Club Cab
Hyandia Accent
not sure which top tail light you mean? do you wish to replace bulb or actual lamp on the rear screen? this is the high level brake light ! OR do you wish to replace bulb in one of the rear tail lamps offside/nearside ? which ever ? the h/level brake light bulb is accessable for bulb from the rear panel on hatch behind lamp bulb is 16 watt capless push in type
Nov 10, 2008 | 2003 Hyundai Accent
Brake Light Inop - bulb ok
Check the bulb socket, clean the contacts, if they are ok check for a poor ground.
Sep 17, 2008 | 2001 Jeep Grand Cherokee
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
