Question about Kodak Ektaprint 95 Copier
Orange roller When I try to copy, the paper jams right at the orange roller. It appears to be some kind of white substance built up on the rollers. What can I clean them with.
  • Kodak Expert
  • 287 Answers
Re: orange roller
I hope this helps. The "orange roller" is most likely the fuser/fixing roller. If that is so then it is probably made of hard rubber that is encased in a plastic coating. That plastic coating acts like the teflon in a cooking pan but in this case it is toner and paper you don' t want to stick. Through extreme heat and pressure the toner is bound to the to the paper by the "orange roller". With time and wear the plastic coating will separate from the rubber roller and appear whitish and almost foreign looking as it looses it's bond to the roller.There is also a set of brown plastic fingers that ride against the orange roller that act like spatulas to separate the paper from the roller as to prevent the paper from wrapping around the roller. They can have toner build up or other defects with use. Both the roller and the fingers are natural wear items and will cause jams,especailly fan-folds.
Posted on Dec 23, 2007
  • 69 Answers
Re: orange roller
Hi im jules_09,is it all the fuser area?to be safe try cleaning it first with alcohol,if the that doesnot work try metal polish,just be sure its not the opc drum that make the copies ok,get a fine and soft cloth so you would not damage the roller,urb a right amount of metal polish to it then then rub it with cloth gently in one direction the best directio is carefull not to scracth it or the drum
Posted on Nov 12, 2007
0 characters
3 Points
Cannon pc 921 won't feed paper from tray or bypass, shows P for out of paper but tray is full I can't find any jam
Try cleaning the feed roller using ammonia solution. The sizing used in the manufacturing of paper has waxy substances that accumulate in the pores of the rubber rollers and reduce the friction on the feed roller..
May 29, 2014 | Canon PC-921 Black and White Copier
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
Waktu ngeprin sekali lancar setelah itu paper jam atau kerta ngegulung
1. Check and/or Remove Paper from top output assembly.
2. Clean pick-up roller if it appears to be dirty or have sticky substance, etc. Replace roller if worn or damaged.
3. Check if the top paper output and rollers are free of damage.
4. Cycle Power or partial reset printer
5. Put only 10-25 sheets of plain white letter size paper in the input tray
6. Flip the paper stack over to verify printing on correct side.
Please follow the below web link steps
Dec 28, 2010 | HP LaserJet 1020 Printer
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
Paper Jamming
See if canon sell a Roller PM kit and replace the rollers.  you could try cleaning them with a lint free cloth and some fresh water.
May 28, 2009 | Canon PC-921 Black and White Copier
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper jam problam
no the tefflon is not fitted properly as you again open the printer and clean the tefflons upper side as any of the greece substance is got stuck up on the tefflon to cause this problem.also clean the pressor roller of orange/red colour with the isoprophyl and then slowly rub the liquid with very dry tissue.your pressure roller is perfectly alright as this paper jam problem comes very often after the tefflon is changed if it is not fitted and cleaned properly.
Jul 02, 2008 | HP LaserJet 1010 Printer
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Printers & Copiers Logo
129 people viewed this question
Top Kodak Printers & Copiers Experts
Michel Smith
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Printer and Copier Expert? Answer questions, earn points and help others
