Question about GE GSH22JFR Side by Side Refrigerator
Repairman stated he cannot fix refrigerator coolant leak
Repairman stated that our Amana refrigerator has a coolant leak and aluminum coils so it is not repairable. Is this correct? The unit is 12 years old but has always been very cold and reliable.
  • 136 Answers
What you want to do is replace the coolant tubes in your fridge... i would suggest calling in another repairman and see if he says the same thing please rate my solutions... please.
Posted on Jun 30, 2009
Amana LWA60AW finishes cycle OK, stops, but over a few days the tub is slowly being filled with water. Why?
your watervalve is leaking this not easy fix the valve is under top of washer. turn off your water at washer this can flood your area, call repairman 100-200 dollars for this
Jan 25, 2015 | Amana Refrigerators
"hissing" freezer, red hot coils, and daily leak
the thermostat must not be functioning properly...
you need to replace them
Jun 02, 2008 | Maytag MZD2766GES Side by Side...
Anyone else have a Amana refrigerator AFD2535FES develop a refrigerant leak in the sealed cabinet?
You can seal off those lines going around the door that's called the Yoder Loop. but as far as the class action lawsuit or getting Amana or Whirlpool to pay for the anything good luck. There are very few success stories there.
Apr 04, 2017 | Amana Refrigerators
Amana BR18V1S is running but fridge temperature is low (slightly cool) Checked everything, cleaned coils (very dirty) Freezer OK.
Check and see if the freezer coils are blocked with ice. If not you may have a refrigerant problem as you stated the coils were dirty. The new refrigerants when hot tend to clog the capillary tube which feeds the refrigerant to the evaporator (freezer coils)
Jun 06, 2011 | Amana Bottom Mount Refrigerator 22 cu ft -...
My Amana ABB222ZDES fridge is only 4 years old and it stopped cooling. The fan still runs but no cold air comes out in the fridge or the freezer. There is also oil in the tray that is suppose to catch...
The presence of the oil tells my that you have a refrigerant leak in the coil....
The leak will need to be found, fixed, and the system recharged....
You will need to find a professional to do this but make sure that you get a complete price and a promise that it will be fixed with a warranty before giving the go ahead...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Amana ABB222ZDES Bottom Freezer...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
8 year old Sub-Zero model 690. Condensor coil leaking
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
Amana Double Door refrigerator not freezing in the freezer side.
sounds like a leak ,as long as the compressor fan is running it is a leak. it can be fixed by a technician only due to the tools needed for the repair. these tools cost well over 1000usd and may not be worth purchasing for a single repair.
Phil
Jun 10, 2009 | Refrigerators
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
249 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
