Question about Network & Wireless Adapters
Draftn connection My acer has a draft n built in card but will only connect to my netgear max draft n router at 54 mgs can you help
  • 39 Answers
Re: draftn connection
What is the model number for the router you are using?
Posted on Nov 08, 2007
0 characters
3 Points
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Network & Wireless Adapters
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection Interrupted periodically
To rectify the intermittent wireless connection, you will have to change the wireless channel on your wireless router. The channel that the router is using is getting interfrence causing your wireless connectioin to drop.
Hope this helps you.
Apr 02, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
How do i find my network key code?
Connect an Ethernet cable between the router and your computer.
Access the router's built-in web-interface.
Browse to the "wireless" settings, to display the password & network-key.
Dec 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Stupid router
May 26, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
A good router to get with these would be a netgear WPN824 router. This is probably the best solution for you and has plenty of power. With it/ you will get an installation CD to help you. For further help with the installation, simply send me a message.
Feb 18, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless connection
Try turning off encryption on the router. If you can connect after that it is an encryption problem.
Dec 25, 2007 | Network & Wireless Adapters
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Network & Wireless Adapters Logo
94 people viewed this question
Top Network & Wireless Adapters Experts
 C. Dante
C. Dante
Are you a Network and Wireless Adapter Expert? Answer questions, earn points and help others
