Question about Kenmore 98702 Stacked Washer/Dryer
My kenmore 417.94812301 stacked washer / dryer slow leak
Approximately 6 years old, the washer has developed a slow leak on the Left/front side, as facing. Any thoughts, please. I'd rather repair it myself if possible.
Thank you.
Dr. H
  • 672 Answers
I am leaning toward the pump leaking. Physical inspection will tell. Sears website will show exploded view of parts. Start under Parts direct tab. Good luck. link to sears. www.sears.com
Posted on Jun 30, 2009
Leaking oil underneath clothes dryer
My mom has a Kenmore dryer that is less than a year old. It leaks oil under front side. What can I do to fix it.
Jun 29, 2012 | Kenmore Dryers
Remove front panel on kenmore washer dryer stack model110.26182
Model# 110.88752799 Kenmore stacker washer/dryer
Q; How do I remove the front control panel? (to remove the timer dial, to replace a switch, etc)
A: reference diagram- http://www.searspartsdirect.com/partsdirect/partsdirect/printSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK1105180-00001.png
-remove four crews (#8 on diagram) from left and right sides.
-remove one screw (at #21 on diagram) from the bottom of the panel.
-remove #7 panel from the left and right side
- this will expose a thin metal catch (#9) on each side. With a small finger or screw driver, push down on the top of this metal strip where it bends horizontally. This will compress the spring (#14) and release the catch.
- the control panel will fold down now.
Jun 01, 2012 | Kenmore 98702 Stacked Washer/Dryer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Oil leaking from washer
    if it smell like wd 40..your transmission is defective,,need help replacing post question,,
    Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
    Can't separate washer from dryer to fix leaky hose
    Sesler, Does your model number beging with 110? If it does you should not have to remove the dryer, taking a puddy knife and pushing on the clips on the left and right side of the washer top should release the front panel. Here you should be able to access any hoses and the top should lift. If your washer does not begin with 110 disregard this post...Catriver..post back.
    Aug 24, 2006 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 98702 Stacked Washer/Dryer Logo
    475 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
