Fault with main board. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/
SOURCE: blue lights standby only no channel open
please confirm brand and model number so I can assist you
SOURCE: pls give an service mode
Try this :
simultaneously press "DISPLAY" button on remote handset and Volume- button on the front
panel of television receiver for 6 to 8 seconds to get the various service menus.
• To access any parameter , use Up/Dn keys of Program/Channel
• To change value of any Parameter, use +/- keys of Volume
• To exit POWER switch off the set
Good luck
SOURCE: TCL tv only turns on in afternoon
The on timer is most likely set resetting factory defaults will not deactivate the timer that has to be done manually
