Question about LG Vu CU920 Cellular Phone
Ringtones to message alert tones
When i go to set ringtones to message alert tones it only lets me set the installed sounds.
    Problem Solver:
  • 6 Answers
For this check out this website www.lg-vu.com
but to do so make sure you have a data cable
Posted on Jul 01, 2009
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How do i install a new ringtone for incoming messages on a samsung s5600 mobile.
Hi, you have to download new ringtones for you phone by browsing with the phone, downloading and installing the ringtone and you follow the steps below to use your desired ringtone..
  • Go to menu display and light and press for widget.
  • Tick sound settings box and click out to main screen.
  • Pull across the little tap at the side of the screen and press the phone icon.
  • At the top right hand side click the little box and scroll down to New message.
  • You will see a box containing Message alert type and another box with Message alert tone.
  • Just select a tone or go search for one by selecting sounds.
Hope this helps.
Apr 15, 2011 | Samsung S5600 Unlocked Cellphone with...
How can i change my message tone on my samsung f480 from the standard tones set on the phone
Instead of changing the ringtone settings, tap the message alert tab (in the top centre of the display).
A set of message alert settings appears . You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
To change the Message alert tone, press the Message alert tone panel .
In the menu that appears, press Change.
Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds) .
In this example, press Use my alert tone.
Press the Sounds option. In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files, Ringtones that are loaded onto the phone, or My voice clips .
In our example, we'll again choose a file from our Music folder.
Press the Music option. A list of suitable MP3 tracks appears.
Tap the one you want in order to highlight it.
Press Options, then tap on the Select menu option to install it as your message alert .
You are now taken back to the Normal profile settings, where the Message alert tone has changed .
To save this change, press Options and then Save .
Alternatively, press Back and you will be asked whether you want to Save? Press Yes
Jan 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
How can i change my text message tone on my samsung f480 thaks
Please Follow these steps to change
  1. From the standby screen, press Menu.
  2. In the main Menu, press Settings.
  3. In the Settings menu, select Phone profiles and press.
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use and press the Edit button at the bottom of the display.
  5. You are taken into the profile settings. At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. Tap the message alert tab (in the top centre of the display). A set of message alert settings appears. You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
  7. To change the Message alert tone, press the Message alert tone panel. In the menu that appears, press Change. Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds). In this example, press Use my alert tone.
  8. Press the Sounds option (Figure 16). In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files,Ringtones that are loaded onto the phone, or My voice clips. In our example, we'll again choose a file from our Music folder.
  9. Press the Music option. A list of suitable MP3 tracks appears. Tap the one you want in order to highlight it.
  10. Press Options, then tap on the Select menu option to install it as your message alert.
  11. You are now taken back to the Normal profile settings, where the Message alert tone has changed. To save this change, press Options and then Save. Alternatively, press Back and you will be asked whether you want to Save? Press Yes.
Thank you Sir, Have a nice day.
Sep 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
On the LG VU CU920, how do you set ringtones as message alerts?
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
Jun 02, 2009 | LG Vu CU920 Cellular Phone
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Setting ringtones as you text message alert tones
You CAN set a song as your text alert tone. Here are the steps:
1- Go to: Settings> Profiles>
2- Select your options (e.g. normal, vibrate and ring, etc....)
3- select Options> Customize (2)>
4- Highlight "Message Sound" and select Options> Customize (2),
5- Then browse to the folder your song or sound is in (e.g. audio) and select the file you want to use and save it.
I noticed that the songs have to be under 30 seconds to use as any type of alert tone for calls or texts.
Hopefully this helps.
Aug 10, 2008 | LG Shine KE970 Cellular Phone
I cannot change the message tone on samsung j700. there are no sound settings, only profile settings, yet in the profile settings the only option is to change the ringtone and ringtone volume, there is no...
It took me many hours to work it out!
- Menu.
- Settings.
- Phone settings.
- Phone profiles.
- Select (highlight) the one you want &.
- Select OPTIONS with the left soft key.
- Click Edit (1).
- Use the directional key (right) to highlight the New Messages.
- Scroll down to Message Alert.
- Left soft key OPTIONS & select edit (as above).
- Then click the directional key until you hit either Downloaded Music or sounds (depending on where you stored your sound file).
- Select your file.
- Left soft key & select SAVE.
- Then that's it, done!
Please email me with if it works for u or not. mattconway1992@hotmail.co.uk
May 05, 2008 | Samsung Cell Phones
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
LG Vu CU920 Cellular Phone Logo
222 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
