Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore model 665
Bare with me for not knowing the correct terminology but the arm that spins well... no longer spins. I thought it sounded different one day and now I notice that my dishwasher is getting really dirty inside and it never did that before. I think the water is no longer being sprayed around by the arm thingy.
Thanks in advance for any help.
    Scholar:
  • 78 Answers
You need to check the arm's holes for clogs. If the water is filling and draining well, the only water that circulates is being pushed up through the center hole or tower.
The angles of the holes cause them to be little jets when the water rushes out. No water getting through = no jet = no spin.
Posted on Jun 30, 2009
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
I have a Kenmore built in dishwasher. Serial Number 15989990 Model 665. My dishes are not getting clean. Lots of residue on glasses on top rack and dishes streaked. Any ideas? We thought it might be the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My model # 665-16264402, Kenmore Elite. It's not cleaning the dishes on the top rack & barely on the bottom after even running it twice. It has an automatic filter so I know that's not it. Please...
Dishwasher
How to Buy
heatman101
Jan 01, 2011 | Kenmore 24 in. 16269 Built-in Dishwasher
Kenmore 80 series washing machine model stopped spinning
Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
Mar 21, 2010 | Kenmore Washing Machines
My kenmore 665 dishwasher will not pump water to the lower and upper spinner arms. The pump entry screen assy seems to have one tear in it and is dirty. However water does come out if I take off the lower...
Good eye--- Pull kick panel and look underneath. use a bright light to see if there is any drippage or what looks like corrosion on bottom of aluminum motor case. If you see this crud, then motor/pump seal has failed and motor is bad. About 100 motor/100 labor. Let me know if info helps- ED
Mar 02, 2010 | Kenmore Dishwashers
We have a Kenmore dishwasher model #665 15831971
4 step check
1. make sure the in coming watter is hot. solet the faucet run until this is so.
2.add or completely fill rinse aid .open and close door 3times then fill somemore that will take the air out of dispenser andallow you to completely fill dispenser.
4. add correct dishwashing soap
once you did all of that your problem should be gone. let me know if i have been of some help.
Feb 26, 2010 | Dishwashers
Suspect blockage top rotating washer arm does not spin
Both arms (upper and lower) are fed from the back of the machine, when you close the door the arms make a water tight seal with the pumped water in your washer.
Check to see that when the machine is full that both the arms will turn with very little pressure. (watch out for forks sticking out of the cuttlery tray etc.)
You can usually clear a blockage by putting a bag over the back of the arm that engages with the pumped water on the arm that "IS WORKING" this will increase the pressure to the arm that is not working usually freeing the obstruction.
Nov 07, 2009 | Kenmore Dishwashers
I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Feb 02, 2009 | Dishwashers
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
314 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
