If i don't drive my car for a certain amount of time example,if I get from work at 2pm and I don't drive it until the following morning shifting lever seems like stucked and hard to shift from park to drive or reverse
SOURCE: 2002 Ford Escort: Shift lever stuck in Park position.
we do not have an escort but we are having the same prblem with our expedition...it is the break sensor switch near the petal and only about $13 dollars to repace. Easy plug,unplug instal
SOURCE: 96 escort manual 5 speed stuck in reverse
Is the stick moving? or is it 'stuck' in the reverse position as well? There are adjustments but it seems more likely that your 'stick' has come unstuck from the gear levers that actually put the gears in the right spot. Have someone look at the transmission while you move the stick to see if the levers are moving and put your response here.
SOURCE: shift lever is loose and won't shift
Yes you can repair it your self, check under the dash where the trans cable hooks to the shift lever, where the eye of the cable hooks on there are two screws, if these are loose the truck will still shift but the free play makes slack and the cable will not move all the way. If this piece is not loose you will have to lower the steering column and check this shaft, they are know to split in two and with the column down they are easy to change.
SOURCE: My 97 F250 wont shift out of park? Engine starts,
most likely your brake switch is out. If you had a scanner you would be able to see if the computer see's you pressing on the pedal. Or if you know how to test you could check to see if it switches ( completes the circuit ).
Owners of a Toyota 4Runner might panic when the gearshift begins to have problems. Knowing a couple of the things that often go wrong in a 4Runner can help a driver diagnose or even repair the gearshift himself. Following are some of the more common shifting problems with 4Runners, and a bit of information on what to do next. One of the leading causes of gearshift issues in automatic 4Runners is a bad "shift solenoid." In automatics, shifts are controlled by shift solenoids, electrical coils that change gears automatically. These solenoids can go bad over time and cause stuttering between gears, or prevent shifting beyond a certain gear. Shift solenoids can be purchased and replaced on your own. By consulting the owner's manual, you can determine the location on the valve body of your vehicle and check shift solenoids for breakage or rupturing. Replacing these on your own isn't terribly difficult, as long as you are certain the shift solenoid is the problem. Tutorials are available in car repair manuals and sometimes are posted online. When a 4Runner begins to have shifting problems, the transmission is often fingered immediately as the culprit. A driver might change the transmission fluid and filter, only to find that the car slips into the same shifting problems. Four-wheel-drive vehicles utilize a transfer case that ensures shifting between two-wheel and four-wheel drive. If a vehicle has a difficult time shifting into two-wheel or four-wheel-drive high, but works on four-wheel-drive low, examine the transfer case. Common problems include linkage breaks and worn gears. Sometimes, the gearshift on a manual simply doesn't feel right. The vehicle might come out of gear too easily or have a problem upshifting or downshifting. The shift lever seat is the well in which the stick shift rests. After years of use, pieces might break off, bend or rust, causing problems with gearshifts that don't stay where they should or have a hard time getting there. Fixing your shift lever seat is quite simple and takes about 45 minutes. Once the boot cover and plate cover have been removed, you need only examine, remove debris, grease up, and reassemble. Such a fix can cost serious time and money at a mechanic, so try it on your own if you have the time and the proper equipment. The proper equipment includes a screwdriver and/or wrench to remove the boot cover and plate, a soft cloth to remove dirt, and grease for lubricating the shift lever.
Shift Solenoids
Transfer Case
Shift Lever Seat
Good Luck.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park
and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car wont downshift
sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Transmission
will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
Shift indicator
directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing
and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
Hard to shift gears on Manual
transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Automatic transmission shift lever
hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish
delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
