No cool air fromm swamp cooler, water is on.
I have no cool air coming thru the vents. Water is on.
Thank you for your help.
Diana
    Sergeant:
  • 340 Answers
Is the pump on? pull side panel make sure every thing is clean . Tom
Posted on Jun 30, 2009
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
Swamp cooler works i can hear the pumpon water is turned on but not getting cool air
just because the pump is on dose not mean its moving water. impellers can break and pump can get air lock
Aug 01, 2010 | Mastercool 67680 Evaporative Cooler Air...
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Jun 25, 2009 | Heating & Cooling
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
