Question about Creative Labs ZEN V Plus MP3 Player
Zen frozen i've had my zen for about a month now and yesterday i went to shut it down and it froze on the shutdown screen. i tried pressing the reset button but that didn't work so i left it to run out of battery and connected it to my pc this morning and the rebuilding library screen came on. i have now left it for a day yet the rebuilding bar has not changed, even when i disconnect it from my pc. any suggestions? thanks
  • 537 Answers
Re: zen frozen
Go to recovery mode, and do a disk clean up. If that doesnt work, then you might have to format it.
Did you reset it properly? To reset your zen, put a pen head in the hole under the power button for 20 seconds
Posted on Nov 08, 2007
0 characters
3 Points
My creative zen 4gb will freeze when playing any media
It is possible a virus has infected your device. If there is no virus in it, then it require re-programming. Visit and find the appropriate firmware and tool. Try to reprogram it.
Jul 06, 2009 | Creative Labs ZEN Vision:M Digital Media...
My mp3 player is frozen and wont unfreeze My Zen Creative MP3 player froze on me, it just keeps showing the shutting down screen and won't do anything else. I had previously dropped it outside and found...
Try pressing the reset button on the side. If it starts up go in to the utilities menu and reset it. That may fix it, or you may need to reload the firmware. You can get the firmware from the Creative support pages.
Jan 04, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Cannot shut down without resetting
Are you positive that your battery has enough juice in it? This happened to me as well, almost went bonkers only to find out that the battery is almost dry. Try popping the charger for half a day, or leave it in your USB for about a day and see if it helps. If it doesn't help, then you might want to try the Recovery Tool
Oct 17, 2008 | Creative Labs Zen Digital Media Player
Zen Vision: M Frozen for good?
. How to reset Zen v +
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Jan 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen v plus frosen
Did you hold down the power button while resetting it?
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative zen sleek frozen!
Try inserting a pin into the tiny 'reset' hole on the bottom of the device.
Nov 01, 2007 | Creative Labs ZEN SLEEK MP3 Player
It's permanently frozen
Sounds like you have a bad hard drive and will need to get it replaced. You should take it to a technician, or if you feel confident enough, buy another hard drive and install it yourself.
Aug 30, 2007 | Creative Labs ZEN Vision:M Digital Media...
Frozen/won't turn on??!!!
Apologies if this answer is offensively obvious. Try putting a paperclip or equally small object into the little reset hole at the bottom of the player if you haven't done so already. Mine froze a couple of times and it always worked.
May 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Dec 16, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
91 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
