Question about RCA F32450 32" TV
RCA F32450, low freq. chirp while plugging it in.
While plugging into an AC outlet, I get a low frequency chirp coming from the main board. I suspect the H.O.T. Anything else I should consider?
  • 767 Answers
Yes the decopling cap
there flat round and bright blue /gray/black
near the Hoz out trans, they should read
10+ meg ohms out off cricut if good
if lower replace them.
Posted on Jun 30, 2009
I have trotter 535 - the following comes on the screen: error 4 - AC line freq out of spec - does anybody know the fix.
Error 4 is a no frequency lock or noisy line voltage. The most common fix for this to install a dedicated outlet. This is required for most treadmills out there.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jan 08, 2014 | Exercise & Fitness
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
I have a 1999 RCA TV model # P52921. It completely shut down. It has no sound and picture. I checked the fuse with my tester and there is power coming out of the fuse. I hear a slight, faint, pulsating...
Check SMPS power supply. DC voltages. First check the power supply
bridge/ diodes. Then check DC votage should be 70% rating of the
capacitor voltage. If the capacitor is dry it will show low voltage.
But the diodes should be OK. Check the high wattage resistors
connected in the power supply. There will be a resistor in the
ac input also. Beyond this check all +DC voltages.
Aug 23, 2010 | Televison & Video
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Poor low frequency
Nope, the circuit boards have nothing to do with transmitting frequencies. There are only 4 items on the Technics 1200 that transmit frequencies...
1) Stylus/Needle
2) Cartridge
3) Tonearm
4) RCA Cables/Leads
If you've already replaced 3 and 4, the problem lies with either 1 or 2. Or the RCA cables you replaced were not done properly, or you used poor quality cables. Double check the work.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Sep 12, 2008 | Technics SL-1210 Turntable
Rca 32flascreen tv
high volatge transformer shorted...or component in hi E.
Jul 18, 2008 | RCA F32450 32" TV
No power/RCA ctc187cl
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Oct 30, 2007 | RCA F32450 32" TV
F32450 color t.v.
check plug ,socket,swith. if all ok than problem in power supply . if it is ok than problem in hor. section.
Sep 16, 2007 | RCA F32450 32" TV
RCA F32450 32" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
