Question about Canon imageRUNNER 2020 All-In-One Laser Printer
My Canon 2020 is putting a black line down the page not in the same place does this mean I need to change the drum unit
    Problem Solver:
  • 7 Answers
Plz. empty waste tonner from it and then clean it. it will resove your problem or check life of drum unit.
Posted on Jul 10, 2009
Canon 2016, vertical black lines.Print and copy, not always
Dear. first change the drum cleaning blade and clean the waste toner from the drum unit safely and then try to copy if the black lines still appears then change the drum then it must solve the issue , If still the problem comes then check the laser unit if there is anything which produce the black lines on the pages.
Aug 14, 2013 | Canon imageRUNNER 2016 All-In-One Laser...
How i can change the change drum IR 2020
Open the front cover. You can see lever on its lock position. Turn the lever to the right (unlock) and remove the drum unit.
Oct 03, 2011 | Canon iR 2016i Black and White Copier
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
When printing the printer ( Canon iR C2880) leaves a line devoid of colour running down the pages. how do I solve this or at least do you know what the cause of the problem is?
The problem is probably the drum unit.Try to take out the drum unit and look at the drum.Normaly the color of the drum should be all the same across the drum,but if there is brown lines around the drum thats mean it is tiem to change the drum unit.
Oct 20, 2010 | Canon imageRUNNER iR C2880 Color Copier
I have a Canon Image Writer 2020. I am geting an
waste toner is full.replace the whole drum unit
Mar 03, 2010 | Canon imageRUNNER 2000 Copier
When I photocopy I get a black line down the page, I am using a C
check the drum unit maybe the drum or the cleaning blade is the problem
Jan 04, 2010 | Canon PC-950 Black and White Copier
I have started getting streaks on Image Runner 2020
Try to print something, if there is any streaks?If no the problem is in copy glass (dadf or platen glass).
If there is streaks on print also,it could be the drum unit ( pull the drum unit out and see if on drum surface is any black streaks), fixing film is worn out, and in the worst case you have problem with toner unit ( on toner unit you have current leackage ) and you need (in best case) clean the contacts on toner unit, and in more expencive case tochange the toner unit.
Oct 01, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 2020 All-In-One Laser Printer Logo
169 people viewed this question
old marine
old marine
