Question about Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range
I have just purchased a brand new electrolux EOG 7330 gas oven, all plumbed in and wired, very small flame on grill and oven wont light, further checks reveal it is set up for LPG. how do i go about converting it to natural gas? (if at all possible,) thanks in advance
  • 64 Answers
Must of those ovens have to be ordered already converted **** job to convert yourself
Posted on Jul 01, 2009
  • Tony Houde
    Tony Houde Jul 01, 2009
    must of those ovens have to be ordered already converted **** job to convert yourself
  • Tony Houde
I have an electrolux EOG6330 gas oven and when I light the grill the igniter continues to spark,the only wayto stop it,is to turn the grill off.Any body know what causes it and how to sort it?
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Aug 04, 2011 | Electrolux EOG6330 Gas Single Oven
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Trouble lighting gas oven. Brand is a Chef
your thermocouple needs replacement
Aug 31, 2009 | Ovens
Can not adjust flame.
It sounds like the grill just needs a good cleaning, plus when you do clean it check that the burner tubes and orfaces are free of any debris.
The orface is a tiny hole inside a small brass threaded insert where the gas blows through into the burner tubes, it is very critical that this is clear as well as the burner tubes.
Jul 29, 2009 | Weber Grilling
Low flame and not heating oven
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
Nov 24, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
Electrolux eog 7330
there is an overheat stat somewhere inside the casing - sometimes on the top[ and sometimes close to the fan. this may be a resettable stat - ie has a little button in the middle to reset.
another way is a thermal fuse - a little cylindrical thing inside a heatproof plastic tube
Sep 17, 2008 | Ovens
Electrolux RM212,F, wont cool on gas but appears to be ok on electric. The flame lights but can only feel a slight chill in the freezer box, and the flame does not seem to adjust with the control.
May 13, 2008 | Electrolux Refrigerators
Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
222 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
