Question about IBM 6400-I2S Matrix Printer
After flashing printer i get x700 exceptiom
When turned printer on came up with b20 status no program
after flashing printer i get x700 exceptiom program int
    Scholar:
  • 111 Answers
Have you tried reflashing it again?
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
Posted on Jul 07, 2009
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
Printer was working fine now just prints junk
Turn the printer off, press the FEED key and hold while turning the printer on. When the status LED flashes once, let go of FEED. The printer will to a calibration, print out a config label and then should be ready to go.
Hope that helps !
Apr 24, 2010 | Zebra LP 2844 Thermal Printer
My ip3000 status says "collecting printer status". I have checked the cords and turned it off and back on. Still won't print. Thanks.
If lights are flashing on the printer, I need to know how many flashes to know what to do. Unless the printer is on and with a ready light, you won't be able to print or collect status.
Aug 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Can't make coffee
Thank you very mach, for support but I was had solution yesterday by user documentation. The mashine was blocked by electronic because was not clean very long time.
B.R. Petko
Jan 21, 2009 | Bosch Benvenuto B20 Espresso & Coffee...
Flash a printer
I can email you the Flash Program.
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: Have Ethernet? You can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
Dec 01, 2008 | Printronix Line Matrix P5215 Printer
Status monitor for Konica Minolta 2400w
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
Aug 02, 2008 | Konica Minolta magicolor 2400 Laser...
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
IBM 6400-I2S Matrix Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
