Question about Dometic Rooftop RV Air Conditioner
My doutherm first it threw a breaker and after
My doutherm is first it threw a breaker and after i let it reset it ran for about 3 min and threw it again so lastly it will run but compressorr kicks off but fan is still blowing keeps disingaging
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Sounds like the thermal overload on the compressor is tripping in and out. This is caused by either a weak thermal overload switch or the compressor is bad. Usually it is the latter of the two. If the compressor is kicking off but the fan is still running, then this is the case. If the entire unit is shutting down due to the breaker tripping, then you may have a bad Start Capacitor or PTCR Device. On the upper unit, remove the shroud and then there is an access panel on the side of the AC. Remove the cover to expose the capacitors. The start capacitor has a small black relay attached to the top of it, make sure that this relay is not burned out. If so, then it will need to be replaced. If it is fine, then I would say that you have a bad compressor of the condenser is dirty.
Posted on Jul 03, 2009
My dryer is an lg tromm dle7177rm. it is 220v. it has ran fine for 3 years but now trips the breaker within 5 min.
If your breakers are old. I'll start by replacing the breaker to the dryer at the box. It is a common failure. Breakers wear out to. Check the power cord for any burnt markings and look at the outlet as well for burnt or discolor contacts. This will overheat as well causing the breaker to exceed the limit and trip it.
Nov 05, 2015 | LG Dryers
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
May 15, 2010 | Coleman Mach III Air Conditioner
Midea model MSB24CR After a while cuts off flashing lights on panel (auto-timer- operation) . Cant restart until reset breaker Thanks
TAKE THE UNIT OFF OF AUTO-TIMER AND TURN THE POWER OFF
AT THE BREAKER...UNPLUG THE UNIT IF APPLICABLE AND WAIT
3 TO 5 MIN...TURN BREAKER BACK ON AND PLUG IN UNIT IF
APPLICABLE AND RE-PROGRAM. YOU MAY WANT TO WAIT TO SEE IF IT RE-PROGRAMS AUTOMATICALLY... AND RESETS...IF
THIS DOESN'T WORK YOU MAY NEED A NEW BREAKER...CHECK FOR ANY LOOSE CONNECTIONS WHILE POWER IS OFF...
Mar 27, 2010 | Heating & Cooling
1999 pontiac sunfire car ran hot and coolant resivor was leakind so replaced it then ran good for 5 min then lost fluid threw leak in radiator turned car off now wont start
Take the spark plugs out all of them and then turn the engine like your trying to start it if you see water or antifreeze coming out of any of the plugs you busted a headgasket.
Jan 02, 2010 | 1999 Pontiac Sunfire
My dryer ran for about a min. It then quit and
Did the circuit breaker trip or fuse blow? Check to see if the dryer is getting power.
Sep 12, 2009 | Dryers
Oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Jan 24, 2008 | KitchenAid KERC601 Electric Kitchen Range
Dometic Rooftop RV Air Conditioner Logo
201 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
