This 10 year old monitor has CCFL back lamps 2008 made,, 2010 monitors have LED, that dont fail. do the flash light test.
http://www.pcdied.com/monitors_and_screens/index.html
https://www.manualslib.com/manual/1062/A...
page 14 in your manual
proves CCFL is there
and most this old have failed, many did only 5 years old.
upgrade to newer monitor, 2010 first here
2011 most are LED now, and can run near forever , unlike any old CCFL monitors made.
even $40 for a refurb sold at walfart.
is way less money that any
new LCD screen nor for sure adding on labor.
crazy to do that. it is econ101. crazy.
SOURCE: Acer al2002w flickers and goes black
Hi....there,
Well, you've got a busted backlight inverter... Need to replaced a new one...
SOURCE: my monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
SOURCE: Monitor restarting randomly
Rarely does a monitor go out due to drivers. Try another monitor and verify that it isn't the computer (it isn't). If the power light goes out it is the power supply (usually inside) the monitor. If the light stays on, it will most likely be the backlight power unit. Browse the internet for the model and parts. Newer units are difficult to find.
SOURCE: my monitor flickers then goes black
It could be the capacitors on your monitor's Power Supply. Open up the lcd and check the power supply board see if you see any "BULGED UP" capacitors. If thats the case you most likely just need to replace the bad capacitors. Go to radio shack or electronics supply store buy the same capacitors with the same mF and volts. If you can't find the same ones then always go with higher voltage. Replace the bad ones with new ones following this video. Make sure you note the negative terminals on the CAPS before you remove them. The shorter side on the new CAP is always negative.
SOURCE: Display coming for 2 sec and then it goes off
Does it work well with other computers?
If you are connecting to a laptop, try switching display modes (like you would do for a projector)
