Broken cable connector in the back of JVC tv
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
  • 69 Answers
If the remaining piece was not part
of the PC board , which is light yellow
theres a good chance with a soldering iron
and a new female coax from radio shack
you could do it . or pay a shop 75.00 to
reinstall one for you.
Posted on Jul 01, 2009
3 Suggested Answers
  • 78 Answers
SOURCE: The connector at the back of the tv where the
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Posted on Jun 30, 2009
  • 508 Answers
SOURCE: cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
The cable connection on my tv broke off how can I connect back to the cable
On most TV sets, the cable connector (also called an F-connector) is just press-fitted into the metal housing of the tuner (which selects the channels). It's not very strong mechanically and is pretty easily broken by tripping over the cable, moving the TV if the cable is too short, or often by cable technicians who overtighten the cable connection with a wrench.
The good news is that this can be fixed. There are two ways. The simple method is to replace the tuner. It's quick but costly as a new tuner may run $100. The second way is to replace the broken-off F-connector. On some sets it's possible to do this without removing the tuner, but not always. This repair may take a little more labor time, but saves the cost of the tuner.
Either way, this is a repair that's best left to a professional. Without the soldering skills and equipment needed, it's possible to do major damage to the TV and tuner circuit boards. I would recommend getting an estimate for the repair from a shop in your area. Yes, there are still places that fix TVs, but they are getting scarce.
Another possible "fix" is to forget about using the TV cable connection and use a VCR or DVR to tune the channels, and just use the TV's video and audio inputs. It doesn't repair the TV, but it gets you back onto the cable.
I hope you've found this helpful. Thanks for using Fixya!
Jan 31, 2010 | Samsung TXM3297HF 32" TV
Broke the Cable input out of the back when moving the TV. Do I need to replace the board and if so do you know the model # and where I can find the part?
that depends on where the break is. may get away with a strip connector if it is just inside the casing of the tv. if broken on the pcb then you will probably require new board.
Oct 22, 2009 | JVC AV-32F475 32" TV
JVC AV-32230 TV
Although I've had some success soldering a few of those lugs back into place, it will be more dependable to replace it with a new part. The TV says, "no user serviceable parts inside". A technician would be your best bet. He should give you an estimate in advance.
Jul 09, 2009 | JVC AV-27530 27" TV
Cable connector broke off in back of tv
Jun 30, 2009 | Televison & Video
Jun 30, 2009 | JVC AV-27220 TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Sanyo tv coaxi wire broke
Let me guess you have broken off your I.F connector ,this is what you connect your cable to on the back of your set,if this is what you are talking about ,you will need to try and repair IF connector or replace your turner.sometimes when this piece is broken off turner is also damaged,there for you have to replace turner.
Dec 09, 2007 | Sanyo DS27910 27" TV
I have a 27 jvc tv
The connector that just fell off when the cable was pulled will have to be replaced by a service center, Sometime the connector will just come out ot the solder joint and can be replaced. Sometimes it breaks off part of the circuit board, if it broke the board it is not likely that anyone will be willing to try to fix it.
Nov 29, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Broken coax input to back of tv
NOT REALLY BUT YOU COULD GET ROUND IT BY BUYING A £20 DIGIBOX (FREEVIEW BOX) AND CONNECTING IT TO THE TV WITH SCART AND ARIEL GOES INTO THE DIGIBOX (FREEVIEW BOX).
MEANS YOU CANNOT WATCH ANALOG ON THE TV ANYMORE BUT DIGITAL IS MUCH BETTER.
Nov 12, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
