Cable connector broke off in back of tv
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
  • 508 Answers
Had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Posted on Jun 30, 2009
3 Suggested Answers
  • 78 Answers
SOURCE: The connector at the back of the tv where the
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
rsheehan
  • 69 Answers
SOURCE: Broken cable connector in the back of JVC tv
if the remaining piece was not part
of the PC board , which is light yellow
theres a good chance with a soldering iron
and a new female coax from radio shack
you could do it . or pay a shop 75.00 to
reinstall one for you.
Posted on Jul 01, 2009
My son was moving his WS-55517 and during cabinet
You better take this TV to the Hospital. A local tech will be able to explain to you what needs done. This is the best solution, as you can certainly make things worse.......And its safer!!!!
Nov 16, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Jun 30, 2009 | Televison & Video
Jun 30, 2009 | JVC AV-27220 TV
Quasar tv atenna/connector broke on tv
Yes if your cable box has RCA yellow, white, red, outputs on it and your tv has RCA inputs on it you can hook it up that way. It'll only cost you one set of RCA cables which are not expensive at all.
May 31, 2009 | Quasar SP-3235 32" TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Jan 16, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke...
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Aug 18, 2008 | Televison & Video
Broken coax input to back of tv
NOT REALLY BUT YOU COULD GET ROUND IT BY BUYING A £20 DIGIBOX (FREEVIEW BOX) AND CONNECTING IT TO THE TV WITH SCART AND ARIEL GOES INTO THE DIGIBOX (FREEVIEW BOX).
MEANS YOU CANNOT WATCH ANALOG ON THE TV ANYMORE BUT DIGITAL IS MUCH BETTER.
Nov 12, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Cable connector broke off at solder for GE 27GT722
Common problem Order 215543 from a company such as Union Electronics..1-800-648-6657 Use only the orginal, the replacement melts to quicky from the heat of the solder. They don't have a minimum order. Also make sure all the tuner shield grounds are resoldered. Be careful. easy to solder short.
Jun 28, 2006 | GE 25GT240 25" TV
Televison & Video Logo
526 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
