Question about Garden
How far does the igition modual have to be from the fly wheel in a line trimmer
  • 508 Answers
Use business card to set air gap
Posted on Jun 30, 2009
Wont go into gear
this happens because the clutch plate is still spinning with the fly wheel. If you have just replaced the clutch it will be because the clutch plate is in the wrong way and the hub is hitting on the fly wheel bolts. If you haven't touched the clutch so far then you will have to check that the clutch slave cylinder is moving the throw out arm or if the pivot has broken off. IF that is ok then there is a case of the fly wheel and clutch plate contaminated with oil and sticking
together or lastly the lining of the clutch plate has become un secured (broken) and jamming on the flywheel/pressure plate. I am betting on the plate in the wrong way round.
Jan 12, 2014 | 1991 Chevrolet Cavalier
I just rebuilt the carb,new plug, and new feul lines on an old poulan weedeater and it still wont start.......?
Hi brett, have you made sure that the coil and fly wheel are clean? You need to clean these with glass paper as this makes the spark.
Sep 12, 2013 | Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
no not fly wheel maybe coil if not sparking check switch fist is on for sure or bad plug coil expessive try squrying some starting fluid in the carb check compression has to be above 90lb to start check and see if carbon has block exhaust port do all this first
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
What distance should the coil be positioned away from the fly wheel
it dont realy matter how far away it is,, but most bikes have the coil just under the fule tank,, thats about 1.5 feet from the fly wheel
the coil wont be upset if its bolted right above the fly wheel as there is nothing in it that the fly wheel can upset,,,,any magnets are all inside the fly wheel and will have little to no efect on the coil at all
Nov 14, 2009 | 2002 Yamaha TT-R 125 L
Trying to remove magneto on 1987 honda xr80 bike will not fire
first you need to get a fly wheel puller. then remove the nut in the middle of fly wheel,insert fly wheel puller,reverce thread,tighten pin and it will pop off fly wheel.when you put it back on remember to line up "woodruff key",its a little notch on fly wheel whitch lines up with a ridge on cam shaft. if you cant fix your problem and you have spark its probobly your coil and condencer.
Sep 05, 2009 | 1987 Honda XR 250 R
Ght225 Weedeater hedge trimmer
try sanding the fly wheel and the coil to get the rust off
Jun 17, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Fly wheel
I believe that the ratchet mechanism is defective or worn. It will need to be repaired.
Nov 17, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
