Question about Creative Labs ZEN V Plus MP3 Player
Creative zen v plus frosen
I've had my zen for about a month and it froze on the shut down screen. i tried pressing the reset button but that didn't work so i left it to run out of battery. i then plugged it into the computer and have left it all day and the rebuild library bar hasn't changed at all. it also stays on that screen even whe i disconnect it from my pc. any suggestions?
  • 1 more comment
  • carrufer Nov 16, 2007
    the docked sing remains in the "do not disconnect " mode at all times after dowload. If I disconnect even with the computer off it reverts to "rebuilding library" and I then lose everything in order to restart. Brand new will try and gat refund
  • Sam2 Apr 01, 2008
    My creative zenv's screen is stuck on the recovery mode screen. I've tried to reset it, but nothibg seems to work. What do I need to do to fix this problem?
  • Anonymous Nov 15, 2008
    I just got my new Creative ZEN I tried to put music on it, but I had tried to put too much on and realised it would take to long. So I tried to cancel the synch. but it wouldn't so I disconnected my zen but it still says 'Docked' and has the usb sign and it won't go away! I held down the reset button but it won't go off or get off the docked screen either. I fI try to plug it into my computer it won't recognise my zen even if I go on to the ZEN Media Explorer. I'll wait until it runs out of battery and try it again. PLEASE HELP ME!!!
Did you hold down the power button while resetting it?
Posted on Nov 08, 2007
The pc froze whill i was uploading music onto my creative zen v plus and now the screen on the handset says docked and has the docked picture on it with flashing red lights either side. the handset is not...
Try holding the power button down for an extended period of time. If this does not work, there should be a small hole on the side of the device that will reset the player. You'll need to use a paper clip to press the button inside the hole, similar to ejecting a cd/dvd that is stuck in a computer. Hold the button down for several seconds to reset the device.
Feb 28, 2011 | Creative Labs ZEN V Plus MP3 Player
My creative zen plus is stuck on play but no music, no other buttons work and I cannot shut it down.
ZEN V
ZEN V Plus
(DAP-FL0036)
  1. Turn off your player (if possible).
  2. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  3. Power on the player.
  4. The reset hole for the ZEN V / V Plus is located on the left side with the player facing up.
Mar 25, 2009 | Creative Labs ZEN V Plus MP3 Player
My mp3 player is frozen and wont unfreeze My Zen Creative MP3 player froze on me, it just keeps showing the shutting down screen and won't do anything else. I had previously dropped it outside and found...
Try pressing the reset button on the side. If it starts up go in to the utilities menu and reset it. That may fix it, or you may need to reload the firmware. You can get the firmware from the Creative support pages.
Cheers
Jan 04, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Omy zen v plus is stuck on the shutting down screen, it has been for about four hours
Press the "reset" button. If it didn't work, upgrade the firmware of this product. If problems still continue, contact the Creative company.
Jul 31, 2008 | Creative Labs ZEN V Plus MP3 Player
Not turning on
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 10, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen v plus mp4's
Jan 11, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen froze
Try the reset. Poke a paper clip in the hole up by the headphone jack.
Nov 25, 2007 | Creative Labs ZEN V Plus MP3 Player
Zen frozen
Go to recovery mode, and do a disk clean up. If that doesnt work, then you might have to format it.
Did you reset it properly? To reset your zen, put a pen head in the hole under the power button for 20 seconds
Mike
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Vplus hangs while charging
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
123 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
