Plasma tv screen does not work, sound does after power failure
  • 458 Answers
I would suspect it has blown a fuse, more than likely on the Y-sustain board due to the power failure causing a surge. Possibly just replcing the fuse may rectify things but if it were to blow straight then the power failure has caused some component damage & would need to be investigated further by a repair engineer.
Posted on Jun 30, 2009
No sound or picture but lights come on sony wega plasma
Typical failure for all plasma tv's is a blown Y-sustain board. Another high failure for all tv's is dried out bulging capacitors in any of the power boards. You likely have one of these problems.
Mar 18, 2015 | Sony KDE-42XS955 42 in. Plasma HDTV
Have a haier plasma tv model#42hp25bat. sound but no picture. can it be repaired?
Did this occur suddenly, or was the picture gradually failing over time?
Jun 05, 2008 | Televison & Video
My Philips 50" plasma screen won't work. the sound
It can be the power supply, Z-sustain boards failures due to bad caps, blown fuses. Yopu should alos check the Y-SUSTAIN board also.
You can see what the boards look like here:
http://www.shopjimmy.com/catalogsearch/result/?q=Philips+50PF9631D+
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 21, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Panasonic Plasma TV won't turn on
my television will not power on at all no lights no anything, Worked fine the day before
May 21, 2010 | Panasonic TH-50PV30 50 in. Plasma...
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Have a Sanyo Plasma TV DP50747 and both picture and sound all of a suden went. I turned it on from the remote and the green power light goes on, but no picture or sound and the power light goes off again...
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Jan 10, 2009 | Sanyo PDP-42H2A 42 in. Plasma Television
Pioneer Plasma TV powered off and won't power back up
Power supply failure-checked Pioneer's website, there is a recall on the power supply.
Nov 17, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Dell w5001c 50 inch HDTV Plasma
power no video, is an indication of a bad panel. It usually requires changing the power board, and the panel. this supplies all boards to receive the proper voltage to correspond with each other to make the TV work again including the LCD panel. also the revision code and firmware needs to be current, to prevent future programming failures.
Oct 23, 2008 | Dell W5001C 50 in. Plasma HDTV
Open Questions:
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
