Question about EdgeStar AP10000HW Portable Air Conditioner
One Year Old EdgeStar AP410W Will Not Turn On
Wanted to move unit so, I unplugged it - decided not to move it so, I re-plugged it in but unit will not start - looked at manual for help - drained the water reservoir - reset the plug - cleaned the filter - checked the house fuses (all ok) but I do not know how to check the AC's fuses - still will not work but was working great until now ????
  • midge150 Jun 30, 2009
    Tried all of those solutions, they were in the owner's manual but none of them worked.
    Tried all the solutions in the owners manual none worked
  • 3,230 Answers
Follow this below link -
http://edge-star.com/support/portable-air-conditioner.htm
Good Luck!!
Please do rating!!
Thanks
Posted on Jun 30, 2009
  • Mukesh Kumar Jun 30, 2009
    It need a deep check, check all unit again.
    Genius:
  • 1,847 Answers
Follow is this link
Let me know
Thanks
Kevin
Edgestar e30
E30 is a door locking failure. The unit attempted to lock the door several times without success. First, make sure your door is closed firmly. Check for anything that may be blocking the door latch. Check that the latch is aligned to the door lock. Unplug the unit for 30 minutes to reset the electronics. If the unit still does not lock, please contact Edgestar at 800-297-6076.
Dec 06, 2013 | EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer...
Climate control panel unit
if voltage to board bad board
Apr 15, 2017 | EdgeStar Heating & Cooling
My Edgestar AP12000HS no longer dehumidifies
Check to see if it is leaking water out from the bottom , also make sure that condensate pan is set properly
Dec 19, 2017 | EdgeStar Portable Air Conditioner ...
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
Light won't come on beverage cooler?
The unit should still be in warranty. Contact Edgestar for help.
Feb 22, 2013 | EdgeStar Refrigerators
I have a GE window air conditioner about year old. It comes with the digital control panel. The light on the power supply cable is on and it passes the test (it trips as it should) however the unit does...
Some of them controls has a small fuse mounted between the touch pad and the control board. If yours is not lit up then the fuse is all ya need. Take the old fuse to radio shack. Unplug the unit if you decide to look. If the control is bad and costly yall can bypass the controls.
Jul 09, 2011 | GE Heating & Cooling
Unit will not return to normal operation. Code P1 indicates the unit is in defrost. No frost present on the unit.
The unit may need to be reset. In which case, turn the Master ON/OFF switch to OFF. Unplug the unit for 10 to 12 minutes. Plug it back in, turn the unit ON and set your controls for the humidity you want to remove. This should resent the controls for you.
Hope this helps you solve the problem. Please let me know.
Mar 28, 2011 | EdgeStar 65 Dehumidifier
EdgeStar AP10000HW Portable Air Conditioner Logo
160 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
