Samsung HLN467W 46 in. Rear Projection HDTV Television
Problem for Samsung HLN467W 46 in. Rear Projection HDTV Television
Samsung 46" DLP
By jetjohn on Nov 08, 2007
TV has no picture but does have sound until all three lights start to flash and then the set turns off. Purchased a new lamp ($131.00) and that did not change anything? according to the book when the TIMER, LAMP, and STAND BY lights flash it is most likely a defective lamp. What else could be wrong? HELP!
Tv has whining sound in back. When i start the tv it attempts to start several times (sound comes on then goes off) then shuts down and all three lights are blinking. TV will not turn off until i pull the plug. The only trouble shooting i have done is to pull the plug and let it set overnight. still does the same thing thanks
Same Problem
Jun 06, 2008
-   Well I have the same problem as the person before. The sound is there for a little but no visual then the TV shuts off and the 3 lights are lite. Then the TV shuts totally off. Tried unplugging and replugging. I don't know what to do?-   mimi1234567
Dec 15, 2007
-   television plays fine then seems to shut itself off and then turns itself back on. plays fine for a while then does the same thing. when it starts back up there is a buzzing sound prior to the picture starting.-   bolamonster
Dec 04, 2007
-   where did u buy lamp for 131.00? please let me know 773 764-8144
thanks
steven-   Guest
Nov 28, 2007
-   The timer keeps on blinking yet TV does not start to show the screen. Sound comes out in about 3 seconds then everything blacks out. I tried to unplug for 24 hours and tried to plug the next day. TV screen comes out and I was able to view TV for about 10 minutes. Then the same process of black out happens again.-   stareast
Best Solution
posted on Feb 06, 2008
Helpful)
ctf1800
Rank: Wiz  Samsung Expert
Rating: 85%, 4414 votes
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Was this helpful?
Yes
No
Solution #2
posted on Jun 04, 2008
Not Rated)
kmysore2
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem. I bought a 43" Samsung DLP and I"m having problems with the tv. Sometimes when I try to turn the tv on it will not come it cycles on and off and finally the lamp light comes on and and the temp light comes and stays. Sometimes I keep trying and some times it comes on and sometimes it won't. It also makes a whining noise at the back. Please help.
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN467W 46 in. Rear
Questions and Unsolved Problems for Samsung HLN467W 46 in. Rear
Do you recommend Samsung HLN467W 46 in. Rear Projection HDTV Television?
Answer
Answer
TV shows a message constantly since 2 days ago to check fan no. 3 and then the tv turns itself off.
Answer
When you plug in the TV it clicks on, shortly after the "power on LED" shut off. If I... (More)
Answer
Is there a broken solder joint I can resolder on the bp94-00385a digital board. It works fine until... (More)
Answer
made weird noises after powering up. picture is black and white, strobing and really strange.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
