Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
My kenmore 106.4429600 is not getting cold. I
My kenmore 106.4429600 is not getting cold. I have the setting on 5 and the milk is still warm.
  • gotchacovere Jun 30, 2009
    I have cleaned around the fan and motor. Do I remove the silver backing to clean the coils?
  • 508 Answers
Clean coils
Posted on Jun 30, 2009
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Our refrigerator started having problems by freezing stuff like milk, now the milk is curdling in a day or two. We have the temp set at 33 and it is still not working properly.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
Just recently, even at the lowest settings (to keep temps warm as possible) the refrigerator is so cold the milk and OJ is freezing. Any advice on what might be the problem?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Kenmore Side by Side Refrigerator
I get an E-01 message when I set the settings and press start on my Cuisinart bread maker. Help!
I'm pretty sure that means the cook chamber is either too cold or too hot Are you putting cold water or cold milk etc. as a liquid without warming the liquid up to about 80 degress fahrenheit first? If you are warming your liquids then you have a more serious problem with your bread machine and you will probably have to have it serviced.
Oct 10, 2010 | Cuisinart CBK-200 Bread Maker
The inside lights on my Kenmore, french door, refridgerator will not go off. They actually melted the dome cover and started warming the milk that sits below.
kenmore / some of these are L G built and there is a recall on this problem. ck with sears . it is a fire problem .. and the unit cannot keep cold properly if light is staying on .. hope this helps mm ..
Oct 01, 2010 | Kenmore Refrigerators
I DON'T GET WARM WATER, WHEN SET ON WARM, ONLY GET COLD
If the setting is only hot and cold, there will be no
warm water coming out. At warm setting if it is
present, it should give you warm water.
Sep 23, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Salton GM-5 yogurt maker
Basic Yogurt Recipe 4 cups (1 quart) milk - whole, 2 %, 1% or skim
1/4 - 1/2 cup instant non-fat dry milk powder
1/2 cup plain yogurt (with live cultures) or yogurt from a previous batch
  1. In a saucepan, combine milk and dry milk and heat over medium heat, stirring frequently to just below the boiling point. Remove the milk from heat and allow to cool until lukewarm (about 100 degrees). To cool the milk quickly, place the saucepan into the refrigerator or a sink of cold water, stirring occasionally to cool evenly. This takes about 20 minutes.
  2. Pre-warm the yogurt maker's heating base by plugging the cord into an electrical outlet. The signal light will glow when base is plugged in.
  3. Add plain yogurt to the warm milk, stirring gently to blend. Do not beat or whip. Pour the mixture into the yogurt container, secure the lid and place the covered container into the heating base. Cover the Yogurt Maker and process undisturbed and out of drafts for 4-10 hours, depending on tartness desired. Yogurt should be partially set after processing and will thicken further after refrigeration.
After processing, unplug the cord from the outlet. Remove the cover and lift the covered yogurt container out of the heating base. Place the container in the refrigerator and chill at least two hours to thicken. If desired, remove 1/2 cup of the yogurt to use as a starter for future batches, before adding any fruit or flavoring. Keep yogurt refrigerated until use.
Oct 28, 2007 | Salton RA5 5-Cup Rice Cooker
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
145 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
