Question about JVC AV-27220 TV
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
    Scholar:
  • 78 Answers
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Posted on Jun 30, 2009
3 Suggested Answers
  • 508 Answers
SOURCE: cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
rsheehan
  • 69 Answers
SOURCE: Broken cable connector in the back of JVC tv
if the remaining piece was not part
of the PC board , which is light yellow
theres a good chance with a soldering iron
and a new female coax from radio shack
you could do it . or pay a shop 75.00 to
reinstall one for you.
Posted on Jul 01, 2009
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
Jun 30, 2009 | Televison & Video
Cable connector broke off in back of tv
VHF/UHF cable connector broke off from back of televison
well it can be fixed but you will need rf connector their cheap send it to a tv shop they will fix for 30-50 bucks sorry
Apr 03, 2009 | Televison & Video
Samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Jan 16, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
BROKE THE CABLE
Radio Shack MIGHT have the part. That little box was the connector assembly and is soldered on to the circuit board. You will need to unsolder the broken connector and solder in the new one. Either that or duct tape and be careful?!
Jun 18, 2008 | Televison & Video
Sanyo tv coaxi wire broke
Let me guess you have broken off your I.F connector ,this is what you connect your cable to on the back of your set,if this is what you are talking about ,you will need to try and repair IF connector or replace your turner.sometimes when this piece is broken off turner is also damaged,there for you have to replace turner.
Dec 09, 2007 | Sanyo DS27910 27" TV
Cable connector broke off at solder for GE 27GT722
Common problem Order 215543 from a company such as Union Electronics..1-800-648-6657 Use only the orginal, the replacement melts to quicky from the heat of the solder. They don't have a minimum order. Also make sure all the tuner shield grounds are resoldered. Be careful. easy to solder short.
Jun 28, 2006 | GE 25GT240 25" TV
JVC AV-27220 TV Logo
203 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
