Question about HP Pavilion dv1000 Notebook
Scrolling down a document
When I scroll down a document, scrolling is real fast or jerky.space bar seems to stick.laptop HP Pavilion dv1000.Carl
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
I have had this problem where the monitor seems to be scrolling the image so fast that it is one big blur. I reloaded win vista from the backup and the problem was still there. One day I happened to tilt...
old DV5-1150us.
vista , vista is good, but not supported, XP is 100x worse..
monitor , you mean the screen, and the Vista mouse is acting wrong. (correct?)
the only word above useful are vista and SCROLLING
not photos posted of the IMAGE on screen wrong.
try a real USB mouse yet, to see if a real mouse works.
that be first. if only SCROLLING FAILS.
this PC can be connected to a real VGA monitors.
see that 15pin jack on the back, if you use a real monitor as test
we can see if the screen internal has problems.
i cant see what you see, and this is like 1000 times more important
a picture is worth a 1000 words. see?
cell phone camera dead? cant send a photo here.
see below here (see icon blue "Photos" one of the most easy forum on earth to post a photo here.....
my guess is your screen is bad.
to prove that attach any disktop screen to VGA Jack.
if the laptop pad is bad, mouse pad use any USB mouse made
plug it in and see if a real mouse works, can be bought for $3 a real mouse on fleabay or borrow one.
Aug 29, 2017 | HP Pavilion dv5-1150us NoteBook
The scrolling option of my dv4000 hp laptop has stopped working, how can i get it up and running again?
Go to the control panel. From there select mouse. In that screen you can configure scrolling on the pad.
Jan 26, 2011 | HP Pavilion dv4000 Notebook
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
My scroll bar at the right ofmy mouse pad stoped working what do i do
  • Click the Windows Start button, select "Settings," and then click "Control Panel."
  • Step 2 Double-click the icon labeled "Mouse."
  • Step 3 Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptopmag-glass_10x10.gif; skip the remaining steps and refer to the "Warnings" section below.
  • Step 4 Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed.
  • Step 5 Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptopmag-glass_10x10.gif is now enabled.
  • Jul 19, 2010 | HP Pavilion dv9000z Notebook
    Scroll bar not working all of the sudden. I use firefox and has never been an issue for my pavilion before. I did use a public wi-fi at a hospital briefly and had to use IE because firefox never works in...
    First, lets make sure that scrolling is still enabled. Look in the bottom right of the taskbar and see if your synaptics icon for the touchpad properties is there. It will either look like the touchpad or it will be a red icon in the shape of a tear drop. If it is there, right click on it and scroll to properties. If it is not there, go to the control panel and click on mouse properties. When the mouse properties window opens, look on the top right hand side and look for the tab marked device properties, click on this tab...this is for the touchpad settings and controls. When this window opens, look in the left hand pane and scroll down to "scrolling", see if the box is checked to enable scrolling....if it is checked, uncheck it, hit apply, then check it again and hit apply again, click ok and exit. Now, if you do not see any of the above and all you see is mouse settings, then the driver for the touchpad has been corrupt and you will need to go to HP support drivers and download a new driver for the touchpad. Go to the link below and put in the model number of your laptop, then in the next window pick your operating system, now, scroll down and find the touchpad driver listed. Download it into a folder on your deskyop, open the file and run it, it will install a fresh driver. Reboot the laptop and all settings will be on by default.
    http://welcome.hp.com/country/us/en/support.html
    May 19, 2010 | HP Pavilion dv6000z Notebook
    Scrolling bar not working.
    Did you try mouse properties? if not go to Start, control panel, double click mouse.
    Jun 12, 2009 | HP Pavilion dv4000 Notebook
    Computer won't stop scrolling up and scroll lock is off
    heyy..don't panic... simple try to use USB(external) mouse & keyboard and for future use i wud recommend you to re-install your drivers or Operating system too...
    Apr 23, 2009 | Acer Aspire 5570-2758 Notebook
    HP Pavilion dv1000 Notebook Logo
    125 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
