Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh AF811dn duplex registration is off. What are the codes to get into it and adjust them? Or does someone know where service information can be obtained?
  • 46 Answers
First of all make sure that the duplex margins are set to zero. This can be done through [user/tools] at the machine. By default they are set to .4 mm I think. If you can't find this or do this don't bother going through service mode to change it.
Posted on Aug 28, 2009
  • 183 Answers
Enter into printer and faxes from the star menu or control panel select the Ricoh and click on the right click then enter properties and go to change or optain accessories and select that the machne has a duplex
Posted on Jul 16, 2009
  • Ricoh Expert
  • 398 Answers
If is only a little bit then its user tools, copy, and edit , set all to 0. If its alot then SP mode in the 1XXX it will have options for duplex adj.
-Carl
Posted on Jul 02, 2009
Why duplex paper jam in ricoh 3045
Clean the roller with water or Isopropyle Alcohol. It works 100%.
Aug 31, 2014 | RICOH - PRINTERS Ricoh Aficio Sp 3410dn -...
My ricoh 2022 is giving me error code sc650 on my ricoh 2022 machine.
Communication timeout error between
SBCU and duplex unit
650 B
The SBCU cannot receive a response
within 1 second from the duplex unit.
• Serial line connecting SBCU and
duplex unit unstable
• External noise
• SBCU board and duplex main board
connection defective or loose
• Duplex main board defective
• SBCU board defective
Jul 22, 2011 | Office Equipment & Supplies
Do you have the code to fix the registration on a ricoh 3260c'' I can not get it to register
if your talking about the yellow part of your image shifting, which would indeed be registration, you can do an automatic line position adjustment using the maintenance tab under user tools. if you keep having problems with this you may need a service technician to take a look. the machine calibrates itself by printing test patterns on the transfer belt, if its failing you may have a problem on the belt itself or the sensors reading the patterns.
Dec 12, 2009 | Ricoh Office Equipment & Supplies
Hello, got an old Aficio 1045 with headcrash. I
The 900 code is the software error code.Enter in theuser and SP modes and configuration the new duplex.For more information please answer.
Sep 28, 2009 | Ricoh Aficio 450 Copier
Ricoh FT-4527, E541 error. I know that the hardware relating to this problem is the fuser, lamp, fuse or fluctuating voltage, but I don't know the key strokes to remove the error code after the part has...
....Nor do you have the parts. I answered you earlier today. If it were a simple fix/ adjustment I'd be happy to provide it. You need a trained technician, and only technicians will have the codes. You can find yourself in even bigger difficulty messing with service procedures that you know nothing about...cut your losses.
Mar 12, 2009 | Ricoh Office Equipment & Supplies
Manual color registration in Service Mode on CL7200 printer
ok turn the thing on and then open it up and bingo jumbalio!!!
Jan 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Paper Jam from the duplex into the Main Unit
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Dec 11, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio 1232c. The registration clutch SP 5804-11 is not making clicking sound in output mode. It jams at point B when duplexing. What part do I need and would cleaning this reg clutch out help?
you need a new registration clutch then probably part number is AX20 0240 i believe but if the reg clutch is faulty i would usually replace all feed clutches at the same time other part numbers are AX20 0239 relay clutch x 2 and AX20 0224 feed clutch x 2
Nov 26, 2008 | Ricoh Office Equipment & Supplies
Duplex Registration
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and locked print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
SP1-XXX (Feed)
1 Mode No.
(Class 1, 2, and 3) Function / [ Setting ]
1-002
[S-to-S Reg.]
Side-to-Side Registration
1 By-pass Table *
2 Paper Tray 1 *
3 Paper Tray 2 *
Adjusts the side-to-side registration by changing
the laser main scan start position for each mode.
[ -10.0 to 10.0 / 0.0 / 0.1 mm/step ] FA
4 Paper Tray 3 *
5 Paper Tray 4 *
6 Duplex *
Feb 06, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
116 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
