Question about Home
After my softener is done with regen water still
After my softener is done with regen water still continues to flow out of the drain from the softener what do I do?
    Sergeant:
    Champion:
  • 235 Answers
The drain float seems to be stuck. Move it up and down , sometimes this helps loosen it to allow it to close.
Posted on Jul 05, 2009
  • 175 Answers
Your softener valve has some rubber gaskets in it that need to be replaced. Hard water over time will rot these gaskets and cause water to keep running out the drain.
Posted on Nov 20, 2009
What causes culligan water softener tank to mak noise
The noise is normal during regeneration and draining.
You can manually set the regen clock to a different time.
There are Noises in My Culligan Water Softener Regeneration System Hunker
Dec 21, 2017 | Water Filters & Coolers
Error Code 1
The fastest I ever saw a Kenmore softener thrown in the dump was seven weeks old. This was at the owner's insistence; just wouldn't remove iron. He bought an Autotrol with a turbulator from me. This was about 15 years ago and it still works just fine. He had his first service call 2 years ago. I've always thought that quality was more important than price, but if you wish to install yourself I can come so close to the "sale" price of a Kenmore.
Feb 04, 2014 | Kenmore 300 Series Water Softener
Kenmore Water Softener does not advance through cycles
You can send to the company for repair too ! If it sill under warrenty to fix it and aslo don't try the step anymore it might cause some parts damage that the service provider my charge you more.
Dec 09, 2013 | Washing Machines
Is there a reset button for a hard water softener
No. But if you are experiencing hard water problems or ran out of salt and have added salt now you need to push the regen button to manually regenerate the softener. This needs to be done 3 days in a row to regain soft water.
RJH2O
Mar 04, 2013 | Dishwashers
How do i manually renerate culligan wg 844
To manually regenerate at 2am push regen button once. To regen immediately push regen button 2 times.
RJ
May 08, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How do i increase softness
A water softener ether softens or it doesn't. If you are getting hardness leak through continually check to make sure that the bypass valve is closed completely. ( the handle where the pipes go into and out of the softener, make sure the pointer is pointing to service). If you are getting soft water most of the time and it goes hard just before regeneration check the incoming water hardness, if it has gone up you will need to adjust the hardness setting on the unit or if it operates on time, set it to regenerate more often.
Mar 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
Constant flow from my culligan soft minder twin water softner
A constant drip to drain or brine refill indicates a problem with the seals in the valve. You need to determine which tank is leaking. The piston and seals need to be replaced.
RJ
Oct 02, 2009 | Culligan Sediment Water Filter
No salt leaving Culligan softener during regen
I have the same problem... did you find out what was wrong???
Jul 12, 2009 | Culligan Sediment Water Filter
Home Logo
239 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
