Question about Magic Chef Refrigerators
Freezer is cold, refrig is warm - Magic Chef Refrigerators
  • mikersanders Jun 30, 2009
    Nope, Freezer is clear of frost.......Infact there is nothing in the freezer.
  • 351 Answers
Most likely a defrost problem, is there frost in the back of the freezer?
Posted on Jun 30, 2009
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
I have a haier 3.3 freezer/refreg. Its 3 months old. The problem iam having is that the freezer is working but the refrig is warm. I looked at the circuit diagram on the back of the unit and did not see...
Gravity - cold air sinks to bottom of refrigerator. Make sure the damper door is open and allowing cold air from freezer to infiltrate into refrigerator.
Aug 31, 2017 | Refrigerators
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
G E side by side refrig . freezer cold but
you have a defrost system problem timer or heater or bimetal tst could have a electronic defrost timer
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Open Questions:
Refrigerators Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
