Question about Craftsman Garden
Craftsman 5.0, chain drive, model #917-299450- no spark ,cleaned the mag and fly wheel, still no spark, and do you know what the air space is between the mag and crank
rockitman187
  • 2559 Answers
SOURCE: cranks ok. no spark.
Sounds like the coil,condenser or both are bad.
Posted on Apr 05, 2009
  • 109 Answers
SOURCE: Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Posted on Apr 16, 2009
  • 69 Answers
SOURCE: craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
Posted on May 27, 2009
  • 101 Answers
SOURCE: timing chain
you need a fly wheel puller.
Posted on Aug 01, 2009
SOURCE: craftsman rototiller 3 5 model 917 299130 leaks
Craftsman rear tine rototiller - runs fine, but can not get the tines to engage. Belt is ok.
Posted on Apr 30, 2010
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
Sep 15, 2014 | Poulan PP4218AV 18" Chain Saw
Engine won't start- I have changed gas, I have a good spark, and no air blockages
Put a nice new spark plug in the engine and clean the carb with carb cleaner. Spray some cleaner in the carb throat, and put some liquid carb cleaner in the fuel tank.
Mar 05, 2014 | Troy-Bilt Super Tomahawk Chipper Shredder...
Mower under flood water for 2 days.
Hi Steve.You will need to get under the starter pully and rub the spark generator with some glass paper and WD40. No doubt the generator has gone a bit rusty due to the water.The fly wheel will need cleaning to. Also give it a warm place to stay for a few days to completely dry it out. This should be ok then. John
Jul 02, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
How to install a ARMATURE-MAGNETO on a BRIGGS &STRATTON 18 H. ENGINE? Is there a certain gap between the fly wheel and the armature-magneto?
removw chop screen and blower housing unplug little wire under mag remove 2 screws and remove mag reverse prosess with new mag but pull mag away from fly wheel and snug screws center magnet on flywheel over legs of magneto place .010 feelre guage inbetween and loosen screws, hold mag against flywheel and tighten remove feeler guage reinstall kill wire on bottom of mag install blower housing and chop screen hope tis helps
Aug 07, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When turning the ignition switch fly wheel does not "turn over" (it hesitates). Action taken: -Cleaned air filter -Changed spark plug -Checked battery cables (to ensure connection are...
Try using a set of jumper cables connected across the starter solenoid. Then you will be able to connect the other ends, and see if engine turns over better than it did before.
If it does, then you need a new solenoid. Personally, I prefer to use a Ford type Firewall Solenoid, but it is bigger and you may not have the space. They do seem to last longer than OEM though.
If engine still exhibits same problem, then your battery is low, or is exhausted. Try putting it on a small charger overnight, then retry with key. If still same problem, replace battery since you have already verified that the cabling and connections is in good order.
Jun 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing coil pack need to know space from mag
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Timing chain
Jul 30, 2009 | 2003 Yamaha YZ 250
Apr 15, 2009 | Craftsman Garden
Garden Logo
242 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
