Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Lcd message "wrong cartridge". I rebooted, replaced an ink cartridge, reseated the print head. What's left?
    President:
  • 2,306 Answers
The wrong cartridge error happens when the printhead goes bad. The only thing to do is replace the printhead.It is QY6-0064-000 for around $40.00
Posted on Jun 30, 2009
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I have all full cartridges, I have tried cleaning the heads multiple times, still i can not get any printing..not even the head alignment will print
try to reseat the ink cartridge, that means take it out, re insert the same cartridge if it is with ion 6 months, if more than 6 months, replace it w/ brand new, the ink might dried up already.
follow this:
Press the Setup button and select Ink Cartridge by pressing the fontu1.gif/fontd1.gif button, then press the OK button. Confirm the messages on the LCD panel and press the OK button to start the ink cartridge replacement.The ink cartridges move to the replacement position.
Make sure that the document cover is closed, and then open the scanner unit.
Open the cartridge cover. Pinch the sides of the ink cartridge . Lift the cartridge out
put it back in the printer.
Close the scanner unit, then press the OK button.
then print a nozzle check
Feb 10, 2010 | Epson RX620 All-In-One InkJet Photo...
"Wrong Cartridge" Message is being displayed on the Canon MP 780
Remove the print head and cartridges.Unplug machine for 30 min.
Repower and reseat head and ink do a head alignment.
If this does not correct it may require service.
Ink Cartridges are the BCI6 and 3 series correct?
If using CLI8's and they are flashing red you have a bad cartridge or it is in the wrong location.If so Canon will replace the bad cartridge.
Jun 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Alarm says "wrong cartridge"
That happens when the print head sensor does not detect the cartridge.
To start unplug printer power cord for two minutes, and see if this can reset the error.
The wrong cartridge error may be caused also by a bad cartridge, therefore ,as first step you need to est a different cartridge, possibly a new original one.
Check also if the cartridge metal sensor inside the ink carriage is dirty and must be clean, in this case use isopropyl alcohol and cotton to clean metal contacts inside the carriage.
If that cannot fix the problem, then there is a lose connection on the wires connected to the ink carriage / print head assembly. TWhen that happens, the wires connected at the back of the ink carriage must be tested and eventually replaced.
Apr 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Print head
That is a strange message unless you have changed the print head recently (or it has become defective). The first thing I would do is try reseating the print head.
Unplug the printer.
1) Remove the 5 ink cartridges.
2) Lift the lever that is just to the left of where the ink cartridges sit. This is the print head lock level.
3) The print head is located under the ink cartridges (if they were still there) lift it out carefully.
4) Inspect for damage but do not touch anything or it can cause problems.
5) Carefully replace print head and lower level until it clicks
6) Replace ink cartridges
Plug in the printer and test.
If you still have a problem -
Call 1 (800) 828-4040 for warranty part replacement or to order a part out of warranty.
Oct 06, 2008 | Canon MP830 All-In-One Printer
Wrong Cartridge
replace print head. print head is bad.
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
209 people viewed this question
old marine
old marine
