After ink refills (3 colors) I reinstalled in printer and it will not print in color. Just in black.
That's means you didn't refill the colour ink properly.
Try this method, use the injection to draw any of the colour of about 2mm of the refill you bought, inject it into one of the tiny holes of the cartridge and draw a little back so as to remove the dirt in the foam inside the cartridge.. That's all
SOURCE: hp 3550 printer color cartridge printing but black not printing
try to clean the black cart :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: refilled cartridge not printing
Try to cartridge manually ,please follow the instructions :
SOURCE: can i print black prints without refilling the
Not certain on that model of Brother but on mine I was able to get it to print by changing the settings in "Print Setup" If you change these so that it can only print in black and whiye, it won't look for the colour cartridge, like mine didn't
SOURCE: I have a HP 1315 all in one. I just refilled the
Hi
Please refer the weblink provided below to get the exact solution.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+PSC+1315+All-in-One+Printer&qry=cleaning+print+cartridges&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=374569&productBigSeriesOid=306883&spid=374568&opname=HP+PSC+1315+All-in-One+Printer&pname_desc=HP+PSC+1315+All-in-One+Print%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+PSC+1315+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=5M&search=0&submit.x=0&submit.y=0&uqry=cleaning+print+carttidges
this should resolve the issue.
Else chat online with HP technician for further troubleshooting and repair.
https://wimpro.cce.hp.com/ChatEntry/Chat.aspx?productOID=1153491&productLine=5M&productSNI=hpphotosma1153702&productName=HP+Photosmart+C6150+All-in-One+Printer&productCategory=421635&SCOID=238445&h_cc=us&h_lang=en&lc=en&PSOID=1153695&lang=en&cc=us
