Question about Singer 3116 Simple
My machine won't sew, the needle won't go down, seems to be stuck
louislevel_2
  • 374 Answers
SOURCE: needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Posted on Mar 15, 2009
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
bargainbox
  • 1388 Answers
SOURCE: I have a brother XR-37. I was in the middle of
Did you find the broken bit of the needle ?
It may be jamming the bobbin case area and hook. Remove the needleplate and bobbin case and clean it all out then report back with progress.
Posted on Sep 02, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
My needle will not go up and down
hi Tamara.
you have not said the make or model.but try this.
Make sure the push your bobbin winder to the right then to the left and see if that solves the problem. Your Old Machine has a Clutch & It Needs to be Released. The Clutch is this little dial that is inside of the hand wheel. In older machines, it was used to wind the bobbin without the needle going up and down.17 Jul 2015
My Needle is Stuck! My Hand Wheel Won't Move ... - It's Just Sewing
you could also go to this link and see if it helps.when you go to this link if a small windows open in the middle just close that little window.
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing
Nov 20, 2017 | Sewing Machines
Brother cs 5000h is totally jammed, hand crank won't turn, needle stuck in down position
I would totally remove the bobbin apparatus & check that area
Oct 09, 2017 | Sewing Machines
Sewing needle won't move
it could be a part is damaged or broken or a timing problem,,it
would be a good idea to have the machine checked.
Dec 09, 2012 | Sewing Machines
Wheel won't move
it's possible that something has come loose or broken, it needs to be serviced
Jan 24, 2012 | Euro-Pro 9130 Sewing Machine
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Aug 02, 2011 | Singer 1507
The needle keeps getting stuck while i'm sewing and won't go up and down. seems like the bobbin gets knotted uo
Have you tried changing the needle? It sounds like it's bent, even if you can't see that it is. If this doesn't work, leave me a comment back. I check back daily, so I'll see it. Leave me any other details you have, if any, any we'll go from there.
May 06, 2011 | Singer 1507
The needle will not go all the way down to start sewing It seems to get stuck part way. I can turn it backward but it won,t move forward. I don,t know whether the bobbin mechanism is stuck or what
Do not turn it backwards because you will mess up the timing, which may already be the case. I would try taking out the bobbin completely and unthreading and see if it turns then. If not, you may have to take it in for service.
Apr 15, 2011 | Singer 3116 Simple
Singer 3116 Simple Logo
577 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
