Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Vertical almost clear lines running systematicly across the scree
I have a rca 52' model d52w14 the lines are not always visible but do not change with time of tv being on---model was made in 2004 and i do not have any other problems--please help
    Genius:
  • 1,139 Answers
Hello rockfordcam,
These lines are called retrace lines they are caused when the blanking pulse is insufficient to turn off the current to the CRTs (guns) during the retrace period (the time when the CRTs internal electron gun is returning to the start position after "painting" the picture on the screen). Since this is a signal problem, it will require troubleshooting to figure out why This is occurring. If you do not have a background in electronics and a working knowledge of TVs I would suggest that you have a qualified TV technician examine and repair this TV for you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 01, 2009
Fuzzy screen and a vetical line
Could be a faulty screen or a GPU issue. I would get it exchanged for a new one.
Jan 19, 2014 | Dell Studio Computers & Internet
Hi weve just bought the tv ,its a LG ,its a clear pic but has a very fine vertical line down the middle ,its like a yellow line
Vertical IC is bad or capacitor 100uf 35v in front or behind vertical IC. Call Mats for Parts 1-800-628-1118 But to make sure is Line up and down or straight across TV?
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 22, 2009 | RCA HD52W58 52" TV
Vertical black bar across the screen
sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
May 19, 2009 | Dell Latitude D800 Notebook
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
