Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Hi I need to get valve replacement for a LSR8233EQO washing machine. Where can I buy this valve or what's the serial number to look for it online thanks
  • 351 Answers
Whirlpool Parts Surplus Google it and i can get you the parts... i can not post links on here so search for that name on google
Posted on Jun 30, 2009
Hi, I have an LG1238C machine that is coming up with an FE error code which I understand is a filling issue. What is the part number that is used when replacing it? Do you have a video on how to do it?
check the little filter on your machine it where the water comes in to machine it a little sieve can get blocked up other than that it could be water valve it easy to change if ther is a repair shop near you take off your old one and bring it to repair shop they should have a spare one or you can order this online give them model number and serial number and they will match it
Jan 28, 2014 | Washing Machines
Water continues to flow into my whirlpool top loader serial #2dwtw4740yq0
Your inlet water valve likely needs replaced. The water supply hoses behind the machine attach to the the water valve on the machine. You will need full model number usually found around inner door to find correct valve.
Jan 11, 2013 | Washing Machines
The hot water will not stop running. The cold water works fine. The machine is off but the hot water continues to run into the machine until I turn the faucet to the off postion..
The water fill valve in the machine has got stuck open or has dirt in it....
To fix this you will need to replace the fill valve or have it replaced...
The fill valve is usually part of the piece that the hose hooks to on the back of the washer...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 07, 2011 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer model LSR8233EQO Serial #CH1829100 water dripping inside washer when off - think on cold side. What is the problem?
Usually that problem is dirt in or a faulty soleniod valve...
Kind of the opposite of these tips that I wrote...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 22, 2010 | Whirlpool LSN1000LW Top Load Washer
It will wash but not drain the water to spin
sounds like the drain pump has quit working. This is a simple repair and you can buy a replacement pump online through the sears site at: http://www.searspartsdirect.com/partsdirect/index.action
Make sure that you have the unit's nameplate data including model and serial numbers
Oct 18, 2009 | Kenmore Washing Machines
Washin machine won't spin
hi the problem you have is with the lid switch. located under the top replace this lid switch thanks the appliance doc
Oct 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water dripping into drum when machine not in use
Your solenoid valve is probably not sealing it is on the back on the washer where the water lines connect. They do go bad after a while and are fairly cheap and easy to replace. $20-$30 dollar range. Just remember to unplug the washer before you replace it. You should be able to order it online using the model number and serial number of the unit. Good luck You should only need a 5/16 wrench or socket and channel locks to replace this item.
Jan 29, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
