The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag MSD2454G Side by Side
maytag msd2758dr not cooling correctly have to turn both sides up all the way. even with that not...
(More)
maytag msd2758dr not cooling correctly have to turn both sides up all the way. even with that not all that cool.
my maytag refrig/freezer side by side started leaking water from the inside and now does not make...
(More)
my maytag refrig/freezer side by side started leaking water from the inside and now does not make ice
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer...
(More)
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer some type of coil or element red hot like the element in the stove. And the water was running down from the back of my freezer, to the front of the fridge and leaking on the floor. It happens every few hours. What should I look to replace of repair? Model # is MSD2756GE
(More)
