Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Ice maker freexes ice together
Make: Amana, 5 years old
Problem: Ice maker. Ice freezes together, have to use a knife in seperating the ice into smaller sizes. Seals around the door are new, Keep the temp. around 4. Freezer otherwise works great.
  • 351 Answers
Maybe too much water going in to the ice maker
Posted on Jun 30, 2009
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Icemaker not making ice cubes.
Amana SXD22S2W refrigerators are made by Whirlpool and what you have happening is common with a couple possibilities. Most likely the W10245167 Water Inlet Valve is not shutting off after the fill time of about 7.5 seconds. If this is happening the water will slowly fill the ice maker tray above the lever that it should and causes the ice to connect together on the top thus not allowing the cubes to be harvested because they are basically welded together as a whole piece. And the other possibility is the ice maker itself is needing an adjustment of the water flow time. Below I will post a Icemaker Repair video telling how to adjust the time and other things to look for. This is possible but most times not always the case. Adjusting the flow time is delicate and a little change can cause too much or not enough water. Lets watch the icemaker a little closer and see if there is ice freezing up in the fill tube behind the ice maker. You have seen the leaky faucets before and an old W10245167 Water Inlet Valve can do just that making a mess inside your freezer and ice maker if leaking. Here is a Whirlpool Ice Maker Troubleshooting PDF You can find this info on this page HERE You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I will be here should you have any questions, Thanks Sea Breeze
D7824706Q Ice Maker Assembly
Aug 13, 2012 | Refrigerators
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Ice maker freeze ice together
If mechanical or electronic then it has to be replaced with a modified one no way to adjust.
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
263 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
