Question about Goldstar MV-1526 Microwave Oven
Venting Ho wdo you convert this microwave from outside venting to inside venting?
  • jwdurango Nov 08, 2007
    This is for a Goldstar under Cabinet monted microwave
  • Anonymous Mar 19, 2014
    Venting moisture on cabinets top
  • 473 Answers
You will need the take the microwave down and take the shell off. Then take the vent fan out and turn it around the opposite direction and it will blow the other way.
Posted on Nov 09, 2007
Thank you for your help!
Posted on Nov 10, 2007
Can the MMv5208w microwave oven be vented into the room? Or does it require outside venting?
alot of these units can just be vented right out front grill of unt. outside would be alot better so that the odors are not being smelled indoors but the fan housing can actually been changed to blow up or you can make it blow out the front grill requireing no venting at all...hope this helps you out good luck
Jan 05, 2011 | Maytag MMV5208W Microwave Oven
Converting the vent fan on a GE Combination Oven
is your house vent connected properly? no restrictions?
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Venting of microwave - house stinks of bacon
Interesting post, because I have the same problem! I have spent the better part of today researching and taking our microwave apart (partially) to inspect the top portion re: outside vent. Everytime the microwave is on, the "active vent door" (manufacturer's term, not mine!) opens. Apparently this is normal. But it also opens when you turn on the vent fan, when cooking on the stovetop. I don't like this feature, because I think it 'overrides' the outside venting system. I double checked our outside vent to ensure that when this oven was installed, the person did in fact allow the flap to be open when the fan is on (he did). So I think what 'our' problem is, is that the microwave active vent sort of interferes with the outside vent, thus more of the cooking smell being blown into the house instead of the outdoors. I was thinking of simply disconnecting the gizmo that make the active vent door open each time you use the oven and/or vent fan option however I don't think that's a good idea as apparently the main purpose of the active vent door is to keep the electronics of the microwave oven from overheating. The more I read about this version of microwave, the less impressed I am with it. Lots of electronic issues with it. I am not fussy either with having the microwave over the cooktop. Sorry I don't have a solution for your problem but I do feel your pain!!!
Mar 21, 2010 | GE Microwave Ovens
Condensation in door glass of GE XL1800 microwave
Your ventilation seals may be aging, but they have nothing to do with microwave energy leakage, (And microwave energy is not ionizing radiation anyway, so it does not cause cellular mutation or cancer)
You should check your grease filters (if you are venting to the outside) or your charcoal filter (if recirculating).
If you are venting outside, check your outside vent flap for proper operation, and check your outlet and ductwork for a bird's nest or mouse nest, etc.
If you have other questions, feel free to contact me directly, because FixYa doesn't always notify us when there are follow-ups.
- William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 09, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
I had the exhaust switched from inside to outside venting, but there is no air intake. What do I need to check?
Check to see if the damper is stuck, either on the exterior vent outside the house or at the microwave. Also, did the blower get turned to point at the desired exaust direction. Unfortunately, both interior possibilities will require removing the microwave.
Dec 27, 2009 | Microwave Ovens
Can this microwave be vented to the outside?
Yes, this microwave will vent either out through the top or the back. A damper will be needed if it was not saved when the unit was installed. A list of other items are listed in the installation instructions at this link To GE.
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
If this microwave has vented outside in the past then most likely a bird or something has built i nest in or on the vent blocking airflow. If its always been this way then in order for this model to vent though an exterior duct the blower motor has to be flipped so that it blows upwards and a vent connector needs to be installed. This is a fairly easy process once the microwave has been taken down but can be dangerous because there is a capacitor that holds 4000 volts that can discharge though the cabinet if you're not careful.
Nov 03, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Click on link to Hotpoint. Instructions ore in pdf.
Oct 27, 2008 | Hotpoint RVM1635 Microwave Oven
GE EMO300SS microwave
Yes this can be done.  The unit will need to be taken down and the vent fan will need to be reversed.
Oct 13, 2007 | GE EMO3000 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
171 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
