Question about Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount
I have a holmes blizzard fan and need to clean the blade. how do i take the front cover off
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
Posted on Jul 13, 2009
I have the blizzard table model. Four screws, on the back side of the front panel, sunk in a lil' ways, release the front piece from the rest of the unit, giving access to the blades and everything else inside.
Posted on Jul 12, 2012
I have had the same problem. I own a couple and they are not worth the hassle of disassembling. While the fan is on or off (low setting) spray a cleaner such as Windex. I've found spraying while on is better. Then stick a long Q-tip about 6" through the grill and onto the blade. As the blade spins on the tip of the swab it will collect the bunnies. Its plastic blade will do no harm and the q-tip will not harm the motor. Turn off blade and the grill when finished and you will just need a few swabs around the grill as the Windex has been spraying out from the fan.
Posted on Jul 02, 2011
    New Friend:
Is it safe to wash it off with water? Because it is so difficult to unscrew tha fan. Any suggestion? Thanks!
Posted on Jun 05, 2014
  • Akilesh Bapu
    Akilesh Bapu Jul 11, 2016
    On the Holmes website, it says it's not safe!
Ht38rbu repair noise
Take front of the fan cover off hold the back of fan the push and pull out on fan blades from the center. If blades move in and out .The bearings on motor shaft worn out. If no movement try to blow out the motor with compressed air reassemble then try.
Jul 20, 2014 | Holmes Products Dryers
How do I get the front cover off the Holmes table fan HAOF90?
Should be three clips that fold over the outer cover pry up clips with a screw driver.
Jul 21, 2014 | Holmes Products Dryers
Holmes blizzard table fan
take it to your nearest gas station and get the air hose and spray it with the air then take some w-d 40 and with the long red tube attachment that comes with it spray it in the middle moving parts of the fan.the air from the air hose might turn the blades so stick a pencil or something in there first to keep blades from rotating then spray the dust off the blades with the airhose
Jun 16, 2013 | Holmes HAOF90UC Blizzard 8" Three-Speed...
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
Fan does not osculate all the way. The fan sticks then there is the clicking sound.
The worm hear or drive gear that are mainly made of plastic has stripped out. Just don't use the revolving ossulator option any longer
Sep 01, 2010 | Holmes Products Holmes HAOF951T-U Blizzard...
Fan turns very slowly for a few seconds and then stops
it may have pulled in some hair around the shaft. disassemble and clean
Jun 24, 2009 | Holmes Products HAPF622R Floor / Box Fan
Cleaning the fan
There are 4 small screws in the rim between the ribs accessible from the back. Remove the screws and the cover will come off.
Jun 18, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount Logo
15,774 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
ray gallant
xkikbxr
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
