Question about Camping, Backpacking & Hiking
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
Posted on Aug 21, 2009
This problem should be removed because: It's spam/self promotion
It's in the wrong category
It's irrelevant
It's illegal
It's inappropriate/offensive
Other Reason:
Problem with Flashlights
I have a GE Hurricane lantern model # 17000, how do I get it apart to put new bulb in it?
Posted on Jan 24, 2012
You can't change the bulb. I just tried. To get to the bulb, take out the batteries (the cover on the bottom can be tight and hard to twist off). Then it you look really carefully you can see screwed deep in some wells on the sided. You remove those two screws with a long Phillips screwdriver. Then you can remove the base part and the bulb. You then remove the bulb housing by removing the two screws on it. When you that you discover that there is a circuit board with wires that are welded to the battery compartment. Next you carefully bend the plastic holding the circuit board and it comes out allowing you access to the bulb itself. Now you discover that the bulb has wires soldered (or welded or something) to it that are soldered to the circuit board. Basically, you can't change it.
I gave up. I will never buy that lantern again.
Posted on Oct 16, 2013
  • Off Lynch
    Off Lynch Nov 16, 2013
    Sorry Charlie. I followed your instructions up through removing the 2 deep-well screws. the internal assy came out with ease and the bulb is plugged into a 4-prong plug on top. The bulb came out easily and now I have to find the replacement bulb. As far as the bottom removal goes, I used a large slip-joint pliers to get it broke loose. I remembered how long this light has been on board my fishing boat through many winters and summers. I most certainly would buy another when this one fails.
Coleman Lantern TV #D269 appears to be DOA
If it doesn't work with batteries, and the correct power cord is being used, then it's fried. Try wiggling the lantern end of the plug slowly, to put it in a bind at each end. As long As it's turned on, you should see some sign of life if it's not fried. The plug shouldn't move much, but if it moves, the solder points inside of the lantern to the circuit board could be broken off. If none of that works, it's fried.
Oct 15, 2017 | Cars & Trucks
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
I need to change the battery on a Highgear LED Fuse Micro lantern model #10084HG
It's easy once you figure it out. Unscrew the top and then push down on the exposed screw threads with your thumb. The internal "guts" slide out the bottom.
Feb 12, 2014 | HighGear Fuse Micro Lantern, Red
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
I have a GE battery powered (4 D cells) camping lantern. It will not turn on. The batteries are new and have been tested. Is there a way to remove the fluorescent and check?
Fluorescent lamps need a high voltage in order to ionise the gas inside and make them light up..Torch batteries will not produce enough voltage alone so the battery voltage is boosted by an inverter that is incorporated into the torch or lamp body.
It is unfortunate but the majority of such lamp inverters use the cheapest, nastiest, flimsiest circuitry it is possible to use in such things and having taken a few lamps and torches (of respectable brands) apart and seen such things I find it easy to imagine they were thrown together in a far eastern handbag factory when there was a world slump in handbag sales.
When working correctly the inverter produces a voltage high enough to really surprise anyone touching the wrong parts but they do tend to be unreliable due to the usually low quality.
A handy person could conceivably persuade such a lantern to dismantle and check the switch and wiring and ensure the battery voltage is reaching the inverter but it would need electronic experiece to venture further into the reasons why it stopped working.
A replacement tube could be tried but they fail rarely and rarely do they operate long enough to actually wear out so buying a new tube is likely to be wasted money.
Aug 28, 2011 | GE SteelBEAM FluorescentLED Hybrid Lantern...
I want to take the 17440 air purifier apart to see why it won't start.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 30, 2010 | Honeywell 17000 Air Purifier
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Camping, Backpacking & Hiking Logo
1,275 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
