Question about Epson ACULASER CX11NF All-In-One Printer
Epson cx11nf canner Error C2000
When starting the printer/scanner a scanner problem is notified in the display after error free power on self test. Pushing the start button makes the system operational for print only.
What is c2000 standing for? Is it worth to get the system repaired - after 3 years of operation and with empty toner cartriges?
Thank you in advance for any help.
  • dziu Jul 01, 2009
    Sorry to fully disagree. Finally I made it to contact Epson Hot Line.
    Error C2000 is a software error. To cure this just diconnect the printer from mains and wait min. 15 minutes. (I gave the printer 1 hour)
    Then zurn the printer on and the error is gone.
    Again - sorry to say, but I want my money back because the answer was completely wrong and was leading me to unneccessarily ask for professional repair at notable cost - for nothing.
    Regards
    dziu
  • 2,200 Answers
This error is listed as fusing unit is abnormal
This is caused by abnormal temperatures in the heat roller mechanism. The cost of repair is likely to be prohibitive. If the toner is empty I would be inclined to junk it for a new unit.
Posted on Jul 02, 2009
  • Radio Code Pro
    Radio Code Pro Jul 02, 2009
    Glad to hear the problem has resolved for now.
    As the answer is not acceptable to you please email premium.support@fixya.com regarding your request for a refund.
    Kind Regards.
  • 3,230 Answers
It's a main motor error. You should check the motor connector and gears.
Well, if you are not a tech. than this printer need to repair by a qualified service rep.
Thanks
Posted on Jun 30, 2009
Epson Aculaser CX11NF
plz try to reset the machine by consulting your manual.
Aug 27, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
When turned on, displays a E537 error code. Solution?
error 537 is a failed fuser. You will need to replace it before you can use the unit. cost of a fuser is about $450 retail.
Gremlin11
Nov 12, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson schematic (e511 error)
Hi-
Try reseating all the toners, as well as the photoconductor unit. If all fails do a reset using the panel. Call manufacturer for 562-276-4382 for step by step instruction.
Hope this helps
Oct 10, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson AccuLaser CX11NF
I had this problem. Try unplugging any usb connection to the computer, turn off, then turn on and then try a stand alone copy. It was my USB connection to the computer which had locked up the copier.
After this it was fine.
Jan 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP d135
Try posting your question in the correct section. This category is for Epson CX11 machines
Dec 04, 2007 | Epson ACULASER CX11NF All-In-One Printer
Black toner low Epson Aculaser CX11NF
Try powering the unit off and on. The toner indicator does not always reset immediately in my experience
Nov 02, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
186 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
