Question about Dryers
Have power on main line but dryer won't run and light in tub doesn't work
  • 58 Answers
Check to make sure both sides of the outlet have pwer present, if not, repace outlet or correct wiring problem, as well check to see power cord hooked up correctly on dryer.
Posted on Jul 01, 2009
2 Suggested Answers
SOURCE: Dryer has power, tub spins. Doesn't heat up.
Is the thermostat defective?
Posted on Nov 02, 2011
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
I have a LG front load dryer. We smelled a burning smell. Now the dryer will not power on but the inside light works and the tub turns ! Could this be the thermostats ??
Need to trace the location of the burning smell and if this points to the main power supply or board then an examination will show up the damaged part, it could be a mains filter capacitor or a surge protector.
Dec 31, 2012 | Washing Machines
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Changed door switch and still its like the dryer has no electricty
The nicest problem would be that one side of the 220VAC power line is dead, possibly due to a bad circuit breaker. The drum light runs off one side of the line only, but everything else requires 240VAC (i.e., both legs of the line.) So, if you're really lucky, you could turn off the circuit breaker, turn it back on, and everything will work. If you've got a voltmeter handy you could also verify 120 VAC between each leg and neutral, and 240VAC between the two legs.
If your incoming power os OK, it's an electronic control (aka main circuit board, computer board) problem. The solution could be as simple (and cheap) as just reseating the connectors going to that board, or as simple (but expensive) as replacing the board.
Sep 14, 2012 | Kenmore Elite HE4 Electric Dryer
Breakers seem fine, dryer won,t start and light is not lit. ?
There is probably a fuse on the main line somewhere that may have blown. Mostly not resettable but you have to replace. Try following the main wire from where it comes in up to the circuit board and you should see it. Also just to make sure the breaker is good check with a volt meter and make sure you have power coming into the dryer(on an electric two wires would have to be live on gas only one)
Feb 17, 2012 | Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Gas dryer will heat sometimes and not heat other times kenmore model 72802
sounds like bad gas coils,you have to send the whole model number,it will start with 110. or similar,if the bottom panel comes off,remove it,start the dryer, or in the front panel down near the bottom pop off the cover and look in,if the flame lights and then after 10 to 20 minutes the flame doesn't light you have bad gas coils.when the coils are starting to fail they will work correctly until they heat up and then they won't work until they cool down,the coils are what opens the gas valve.the coils are on top of the gas valve,remove the two phillips screws,pull off the cover,remove the wires from the coils and install the new coils,put it back together and you'll be fine,also while you're in there,get a shop vac and vac out the cabinet,stick it on blow and blow all the lint off of the motor and out of the gas tube,then clean out the duct that the lint filter slides into.if your vent line is a long run from the back of the dryer to the outside,i use a leaf blower remove the vent line from the back of the dryer and blow all the lint outside out of the line,do this once a year,you won't have any fires,your clothes will dry on time and your motor and parts will last longer
Oct 28, 2011 | Kenmore 72802 Gas Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
