Question about Dell Computers & Internet
TSST corp CDRW/DVD TSH driver
I cannot update driver through device manager (since it cant read a CD) and the troubleshooting option to uninstall and reinstall does not work. Get the following error:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
  • 375 Answers
Go to device manager - delete the device, then do a 'find all plug and play devices'
Posted on Jun 30, 2009
I just got a refurbish computer with windows xp pro sp2 and installed my drive and set it master. never had any problems with it before and never had problems with the disc that i use(memorex) it will...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
if this fails to fix the problem
you might have got a bad batch of cd/dvd's or
Aug 25, 2011 | Samsung SHS222L DVD+R Burner
My Samsung combo drive (TSST Corp CDW/DVD SH-M522C) was working better and a few days before I was watching a DVD and pause for a little time to go for wash room. when I re-play the DVD it didn't work....
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Jun 29, 2011 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My dell inspiron cd/dvd drive not recognising CDs and DVDs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 11, 2011 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
I cant read write CD or DVD throgh TSST corp CD/RW/DVD TSH492B drive, Some error is getting, DVD is working Sadik
if your computer came with a motherboard disc the sound drivers could be on it
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 22, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
My TSST.corp TS-H653Z has stopped working the drivers are up to date. However, after looking for a solution I get an error Code 39
make sure that the dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 12, 2011 | HP Computers & Internet
Using tsst corp cdrw/dvd tsh492b. i can't get it to read a mini disc for an installation. what can i do?
make sure that the cd reader is getting enough power test all leads that are attached to the cd/dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd drive then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps don't forget to vote
Feb 27, 2011 | Computers & Internet
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
My CD DVD player won't work. TSST CORP CDRW DVD
This is the latest driver released by TSSTCorp for thier devices.
If this helped please vote kindly
Oct 09, 2009 | Computers & Internet
TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
May 29, 2009 | HP Pavilion DV6700T Notebook
Computers & Internet Logo
326 people viewed this question
Alun Cox
