Question about Canon IXUS V2 Digital Camera
My canon camers is suffering from the E18 error
My camera was dropped into a creek. we were able to get it back and rescue the memory card we suspect that sand is stuck into the lense causing it to stick it has the E18 ...any help?
    President:
  • 1,566 Answers
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Posted on Apr 06, 2010
WHY WHEN I PUT MY MEMORY CARD BACK INSIDE MY CAMERA,IT READS MEMORY CARD ERROR ?
If you have downloaded pictures from your card to the computer the memory card needs to be reformatted to the camera it is being used in. The camera and computer firmware and software are not compatible, you might get away without formatting the memory card a few times but eventually the performance suffers to the point the camera can no longer find clean space to write to. As a rule once you download pictures the card needs formatting.
Jan 18, 2011 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot S2 IS camera showing code E18
Hello there,
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
Dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
Aug 21, 2009 | Canon Cameras
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
E18 ERROR
canon camera hard work just
check your lens
see if the memory card is full or not
Feb 05, 2009 | Canon PowerShot A85 Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
HELP!!!!!!!
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 21, 2008 | Canon PowerShot A520 Digital Camera
Canon IXUS V2 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
