Question about HP PSC 2210 All-In-One InkJet Printer
Replacing ink cartridge
I have installed a new cartridge and the printer is saying remove and check cartridge. Its not my printer
  • 400 Answers
You need to reinstall all the driveres by removing the old one it will get fine then..thank you....remember do that by keeping printer disconneted to the power and to the computer..
Posted on Jun 30, 2009
Replace old car.with new ink car.still saying to change
Look inside the printer where you installed the cartridge. Clean the metal contacts on cartridge and the corresponding contacts in the printer. Do this with cue tips dipped in rubbing alcohol. Then reinsert cartridge and then turn off printer. Wait a few seconds and then turn it back on.
Jul 23, 2014 | HP Photosmart C6180 All-In-One InkJet...
I installed new ink cartridges, printer detects a problem
You could try doing the clean program 3 times and then doing a nozzle check. I have had the same problem with both cartridges since I got mine refilled at Cartridge World and they told me to do this. It works sometimes but when I print again the page doesn't print well and I repeat the process.
Mar 22, 2010 | Canon PIXMA MX310 All-In-One Printer
The window says that the wrong ink cartridge is installed and when I remove it and replace it it says remove and replace cartridge. I have put 2 new cartridges in and they are the right ones. It will not...
sometimes when replacing ink cartridges some idiot that filled them to begin with doesnt reset the calibration they just shove the ink in and box em up!!
its not your printer its who you bought the ink from
Jan 14, 2010 | HP PSC 950 All-In-One InkJet Printer
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer says,move and check right ink cartridge
Unplug the printer. Plug it again and install the cartridge. If the message is stil present, try to install a new original. cartridge.
Oct 26, 2009 | HP Officejet 5610 All-In-One InkJet...
E5 error
HI ...
This error comes in when the cartridge is not installed correct ... I would suggest you remove and then re-install the cartridge using the below steps:
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Installing new ink cartridges
Be sure you have snap the ink cartridge tight, and check the expiration date of the ink cartridge.
Nov 12, 2008 | Dell Office Equipment & Supplies
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
HP officejet 6110xi
Hi , the new installed are genuine ink ? If generic try to replace with original hp ink. the printer can detect if not genuine .
Feb 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
