Question about Princeton Digital VL1812 18.1" Flat Panel LCD Monitor
Not getting any Video or Sync. Power light does come on green but just fades in and out when PC is on and off. VGA connector does appear to be missing a couple pins. Same issue on multiple PC's (Laptop and Desktop).
  • 1 more comment
  • Anonymous Nov 08, 2007
    NO VIDEO OR SYNC. GREEN POWER LIGHT IS LIT. MONITOR TAKES ALONG TIME TO COME ON AT TIMES.
  • hilliakr Nov 12, 2007
    Does anyone have a clue as to what this problem could be?
    Does anyone have a idea as to what this could be?
I have same problem, believe it to be capacitors on the power supply have slowly leaked over the years (mine is Oct 2002).
Some may having bulging capacitors visible. Replacing the bad caps should resolve long start up time.
Posted on Mar 06, 2008
My smasung monitor sync master 753 vga connector broken, what is color scheme for new connector
Colour scheme to re wire is as follows...
Pin Name Function 1
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Hope this helps!!
Jul 19, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Hi my laptop went in for repair and they said it cant be fixed as the vga isnt working? what is this and could it be solved
A Video Graphics Array (VGA) connector is a three-row 15-pin DE-15 connector. The 15-pin VGA connector is found on many video cards, computer monitors, and some high definition television sets. On laptop computers or other small devices, a mini-VGA port is sometimes used in place of the full-sized VGA connector.
DE-15 is also conventionally called RGB connector, D-sub 15, mini sub D15, mini D15, DB-15, HDB-15, HD-15 or HD15 (High Density, to distinguish it from the older and less flexible DE-9 connector used on older VGA cards, which has the same shell size but only two rows of pins).
VGA connectors and cables carry analog component RGBHV (red, green, blue, horizontal sync, vertical sync) video signals, and VESA Display Data Channel (VESA DDC) data. In the original version of DE-15 pinout, one pin was keyed and 4 pins carried Monitor ID bits which were rarely used; VESA DDC redefined some of these pins and replaced the key pin with +5 V DC power supply.
the only solution for that is to replace your vga.
May 31, 2011 | Computers & Internet
Sometimes No Video
Your Vga Driver is corruoted, if you have a Vga card separate reload the driver, if not reload the mother board driver. If the problem still appears, format the PC.
That is the best case. The other possibilty is mother board failure.
Good luck
Feb 21, 2010 | Dell Inspiron 546 MT Desktop Computer
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
I just bought a cat5 cable and to covert to vga male and famle head . But i have no clue which pins to solder together because cat5 has 8 cores , while vga has 15 pins or so can you help
I'm not exactly sure how you expect to use a Cat 5 cable for VGA video (Takes 12 wires last time I looked) but here is how the cable connectors are wired
SVGA (35-37 KHz - 800x600) 15 pin sub D:
6
1 Red (Analog) 6 Red Return 11 (ID0) GND (Color) 11. . . 1
2 Green (Analog) 7 Green Return 12 (ID1) NC (Color) . . .
3 Blue (Analog) 8 Blue Return 13 Horzontal Sync . . .
4 Not Used 9 Not used 14 Vertical Sync . . .
5 Ground 10 Ground 15 Not Used . . .
15 10 5
Jun 22, 2008 | Computers & Internet
13pins "from the inside monitor" "to the VGA 15 pins connector
hai dear,
i checked your problem and found that you open the cover of monitor and you find the two jack of data cable in main pcb and neck card( 2 connector of data cable).plz you cut the connector of data cable and you will find 8 wires in connector.related red(invild extra ground),green(invild extra ground),blue(invild extra ground),black gnd,white,orange,gold(extra gnd) and now you cut the red wire, you will find two wires.so you refix the main red wire pin no-1 of connector and red gnd pin no-6,green main wire pin no-2 and green gnd pin no-7,main blue wire pin no-3 and blue gnd pin no-8.check for the horizental sync and vertical sync wire you should go in main pcb which invild the other connector. there is present in print, h- sync(two wire of h- sync main wire in pin no-13 and other pin no-5) and ver.-sync wire in pin no-14.first you will check the whose h-sync and vert-sync in color and now finally other wires will fix any pin of connector.
Apr 03, 2008 | SAMTRON 55V 15" CRT Monitor
No video from computer input port
Hi there
As far as I know this specific model requires comes out with a convertor box - are you using it ?
Mar 18, 2008 | InFocus LP 755 Multimedia Projector
Open Questions:
Princeton Digital VL1812 18.1" Flat Panel LCD Monitor Logo
67 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
