Question about Polar M32 Heart Rate Monitor Watch
Battery change in Polar M32
How to replace metal holding tab on top of battery?
escapement
  • 2334 Answers
SOURCE: can not change battery on Polar chest strap
Yes, there are a few.
1) As you may noticed, coin and even screwdriver blades are never sharp, but mostly blunt. So, sharpen the edge of the coin on a piece of sandpaper. Get hardened steel screwdriver or very sharp, pointed end file and scrape that indention (groove) to make sure the channel have straight sides, forming I_I shaped groove, but not V shaped groove. When done, insert the sharpened coin and unscrew the battery cover using some pressure as well.
2) In case if the groove is stripped completely, you will have to drill two small holes into the battery cover. Drill them 1mm from the battery cover's edge on opposite sides. Depth of holes should be 0.5 mm. Do not drill through completely. For drilling use 0.3-0.5 mm diameter drill bit.
When finished with both holes, take hardened tweezers, insert each arm into separate hole and unscrew the battery cover.
Do not forget to rate, please.
Posted on Jan 25, 2009
escapement
  • 2334 Answers
SOURCE: Error after changing battery in polar watch
Follow this link:
http://www.polar.fi/en/support/product_support?product=125
This is original Polar support site.Here you will find all the info available.
Rate me, please.
Posted on Mar 28, 2009
SOURCE: How to change the battery on a Polar F11 Heart Monitor
Here are instructions (with images included) on how to replace the battery for a Polar F11: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Posted on Jun 19, 2009
loz0
  • 25 Answers
SOURCE: Polar CE0537
I have changed batterys in these watches but i can only describe the process from memory which may be faulty. You may or may not have to remove the strap depending on whether it covers any of the case back. Unscrew all screws on back and remove. I believe these watches have a triangular spring loaded plate over the battery which needs to be slid out to (bit tricky) note which way up battery is. Replace battery 2032 i think replace cover short AC or AR with +ve replace seal,back,screws etc. this is a link to manual for confirmation http://www.devicemanuals.com/guide/Watch%20and%20Clock/Polar/Polar-F4-User's-Manual-==TVRFM09URXg=.html
Posted on Aug 22, 2009
SOURCE: how to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Posted on Nov 28, 2009
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
Is there a store where I can take my Polar M32 for battery replacement?
The only way to find out is to take it to your local jeweler/watch maker and see if they have the tools to do it.
Or contact them at the following link:
http://www.polarusa.com/us-en/support/service?product=&category=Service+Information
Good luck.
Aug 10, 2010 | Polar M32 Heart Rate Monitor Watch
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
I have a problem changing the battery of my polar HRM watch.
Here is the link:
http://www.polarelectro.co.uk/uk-en/support
As this is direct link to Polar (UK), I will accept FixYa rating only, even if you will not be able to find what you are looking for.
If you are not happy with that- don't blame me (I'm not the owner of this site) and did my best to find a solution for you.
Not happy-do not rate, please.
Jan 24, 2009 | Polar M32 Heart Rate Monitor Watch
Rs400 polar sport watch unable to download tha data
Hello Avira,
Hopefully you have been successful in downloading by now. If not, take a look at the following product support page .
Hopefully this solves your issue. If not, please feel free to contact your local Polar distributor for assistance. You can find your local Polar distributor here.
Thank you for choosing Polar.
-Chris
May 22, 2008 | Polar M32 Heart Rate Monitor Watch
Chenge the battery
Response to Wasilij: The belt is sealed, so it can be used while swimming. It's not meant to be opened. They replace the whole thing, instead of replacing the battery. So sorry, not going to work.
May 12, 2008 | Polar M32 Heart Rate Monitor Watch
Changing battery
Hi cobbie,
It is a good idea to get a watch repair guy to change it for you. They have the tools and experience to do a good job and they seldom charge more than $15-20 to do it for you. The watch casing generally needs to be cleaned, and often the gasket replaced to maintain water tightness.
If you live in the US, you can get a mail order service done here on the watch for $19 that also includes watertight testing, and the job done by experts that do them everyday. If you are outside the US, get back to me and I will find someone close to you.
regards
robotek
No sound
Make sure the sound is turned on the unit. Press and hold the lower left button for a few seconds and you should see a little Sirus like pic on your watch. If you have that and no sound then you have a problem. Maybe try taking the battery out and reinstalling after a few minutes. If nothing works then your choice would be to send the watch to get repaired or live with it. The heart rate does flash if you are under or over your target rates. Good luck
Jan 24, 2008 | Polar M32 Heart Rate Monitor Watch
Problem with RS200 watch
it could be that one of the wires inside of it somehow broke
Jan 22, 2008 | Polar M32 Heart Rate Monitor Watch
Polar M32 Heart Rate Monitor Watch Logo
517 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
